need info on rear brakes (but not how to)
Old Nov 17, 2004 | 06:37 PM
hatchinprogress's Avatar
Default need info on rear brakes (but not how to)
hey i have a question i wanna do rear disc brakes on my '91 hatch but i dont want to have to drop the gas tank, is there anyway i can do brake swap without droppin the tank???
Old Nov 17, 2004 | 06:49 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
Default Re: need info on rear brakes (hatchinprogress)
its just tighter. you could always keep all your current arms and swap only the spindle section outward and cables. ive done it.
drdisco69's Avatar
Where on earth did you hear that? The swap has nothing to do with the fuel tank. Fear not.
Old Nov 17, 2004 | 06:51 PM
Default Re: need info on rear brakes (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Where on earth did you hear that? The swap has nothing to do with the fuel tank. Fear not.</TD></TR></TABLE> i was told that on the ef i would have to drop the tank to run brake lines??????
Old Nov 17, 2004 | 07:04 PM
drdisco69's Avatar
Not the one I did, but I just replaced the soft lines, not the hard ones, and I ran the e-brake cable without dropping it too.
Old Nov 17, 2004 | 07:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Not the one I did, but I just replaced the soft lines, not the hard ones, and I ran the e-brake cable without dropping it too.</TD></TR></TABLE> and thats with teg set up right?
Old Nov 17, 2004 | 07:10 PM
drdisco69's Avatar
I think it was from an 88 prelude, but they're all the same. Went on an 89 CRX Si.
Old Nov 17, 2004 | 11:48 PM
Rednas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">hey i have a question i wanna do rear disc brakes on my '91 hatch but i dont want to have to drop the gas tank, is there anyway i can do brake swap without droppin the tank???</TD></TR></TABLE>
I have never heard anyone drop their tank before to do a brake swap, not sure where you picked it uo.
Old Nov 18, 2004 | 06:19 AM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Default Re: need info on rear brakes (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">its just tighter. you could always keep all your current arms and swap only the spindle section outward and cables. ive done it. </TD></TR></TABLE>
confimed.......this works as well......I did it this way......da to a si hatch
That way I didn't have to get new ES bushings for the trailing arms.
Old Nov 18, 2004 | 07:13 AM
sdcrx9d1's Avatar
Default Re: need info on rear brakes (Mr. B in Az)
The most I had to do on my CRX was loosen the tank straps a bit. Couldnt get to one of the bolts but it was all gravy from there.
Of course the most frustrating thing was reconnecting the cable ends to the bracket thingy inside the car.
Old Nov 18, 2004 | 08:16 AM
Default Re: need info on rear brakes (Sand1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sand1 &raquo;</TD></TR><TR><TD CLASS="quote">
I have never heard anyone drop their tank before to do a brake swap, not sure where you picked it uo.</TD></TR></TABLE> i had seen the (drop the tank info) on ht and thats why i wanted to ask because i dont want to "learn" while working around fuel, and on fourthgencivic.com they say you have to cut/dremel part of the tank to run the lines
Old Nov 18, 2004 | 08:34 AM
EL Vap133's Avatar
No you don't have to drop the tank unless your car was wrecked or something.
Old Nov 18, 2004 | 08:48 AM
Default Re: need info on rear brakes (EL Vap133)
thanks guys now i just gotta get it done
Old Nov 18, 2004 | 03:36 PM
Wes V's Avatar
I've done the swap on my 89 hatchback and didn't have to remove the tank.
What happens is that the parking brake cable runs along the front edge of the tank and the bolts for the brackets are rather difficult to get to. There are some heat shields that have to be removed. No big thing. Just take your time.
It comes in handy having small hands.
Wes
EFstyle
Jan 15, 2008 08:00 AM
socalrex88
15
Sep 8, 2007 10:51 PM
JUSTCRX
17
Feb 18, 2006 11:57 AM
hondaefhatch89
Dec 12, 2005 04:47 PM
JapJunkie
23
Jan 9, 2005 09:28 PM
