3 angle valve job...worth it?
my gsr is due in for a rebuild and i was wouldering if i should have a 3 angle valve jop done to it. would it be done on both the intakes and exhaust? how much would it cost and would it be worth it?
Radius cut seat is better and make sure that they do any valve guide work first so that the seat is concentric with the valve guide. Yes a valve job is worth it if done properly but its all about flow and I'd suggest more port and polish but make sure someone with **** loads of experience does it for you some people assume porting and porting and more and more and more and they go overboard with the **** and actually loose HP because of losses in velocity where its needed. But yes a valve job is worth it especially if the thing is apart.
