Need Help b18c in 91 CRX HF
Old Nov 17, 2004 | 05:47 PM
cspciviclx's Avatar
Default Need Help b18c in 91 CRX HF
Ok well here is the situation
Put a Jdm b18c in a 1991 CRX HF
All went fine
All is installed
Went to start it and No Gas!!
We have tested everything traced wires back to the ecu at our wits end the injectors are not doing anything..
Here is what I did for the injectors
I cut the b18c injector wires and I wired in the crx obd0 harness and got rid of the resistor box and ran it to ground.. the paper work that came with out Cross over harness said to do this.. Is this right ?
Any help will do i have searched but can find nothing..
Thanks
Lance
Old Nov 21, 2004 | 12:41 PM
jungletronic's Avatar
Default Re: Need Help b18c in 91 CRX HF (cspciviclx)
This may be a stupid question, but do you have fuel at the rail?
Old Nov 21, 2004 | 11:05 PM
MykDE's Avatar
Default Re: Need Help b18c in 91 CRX HF (jungletronic)
hey cspciviclx, Ive got the same prob... ive been at this point for the last 2 months and cant figure what the hell is wrong... ive got 32 psi sittin the the rail behind my injectors and they wont shoot in the gas.. the cars cranks over and the cylinders are dry... plenty of spark and all seems good... i know your not supposed to do this but i sprayed a tiny tiny bit of ether into the throttle body as we cranked it over and it immediately started up.... so the baby runs but no fuel.. changed out injectors with some new ones rc 750's (for my turbo) and still same prob... this sucks *** but im glad someone is in the same boat as me.. if you have AIM my name is MykDE or MSN my email is Mikey_Eguchi@hotmail.com..... drop me a line if you get any ideas and if i get any i'll do the same.
rice a roni
Jun 23, 2017 05:45 AM
Trevor123456789
Oct 26, 2013 11:24 AM
MrHopper
25
Apr 9, 2011 02:56 AM
cspciviclx
Nov 17, 2004 06:36 PM
dash
Sep 4, 2002 07:55 AM
