Do I need new Pilot & Release bearing with ACT clutch install?
Old Nov 17, 2004 | 04:56 PM
propulsion1's Avatar
Default Do I need new Pilot & Release bearing with ACT clutch install?
I bought a used ACT XTSS clutch, and it did not come with the pilot or release bearing. Will my current stock ones work or do I need to get new ones from ACT?
I also bought a new 7.5 lbs fidanza FW to go with the clutch.
Thanks.
Old Nov 17, 2004 | 04:59 PM
BlueR's Avatar
Default Re: Do I need new Pilot & Release bearing with ACT clutch install? (propulsion1)
you will WANT a new release bearing, OEM honda is
did the new fidnza flywheel not come with a new pilot bearing?
Old Nov 17, 2004 | 05:02 PM
Opie's Avatar
Since the tranny is dropped you might as well change any and all bearings as needed.
Old Nov 17, 2004 | 05:07 PM
chad's Avatar
Moderator
YES~~~~~~~~~~~~
Old Nov 17, 2004 | 07:28 PM
Default Re: Do I need new Pilot & Release bearing with ACT clutch install? (chad)
Thanks for the reply. Do I need BOTH teh pilot and Release bearing then, or just the pilot?
How much do they run? Should I get the honda ones or the ones for both bearings or the ACT one? I have 60k on my current clutch.
Thanks.
Old Nov 17, 2004 | 07:30 PM
danny98r's Avatar
just go to honda and purchase the bearings...
Old Nov 17, 2004 | 07:36 PM
Mugen Mike's Avatar
Replace them both while the tranny is out -- you would be stupid not to.
OEM Honda bearings are
Old Nov 17, 2004 | 09:54 PM
GZR4DR's Avatar
Default Re: Do I need new Pilot & Release bearing with ACT clutch install? (Mugen Mike)
You definitely want to change the throw out bearing. The pilot bearing is a PITA to change if you don't have power tools and I don't necessarily consider it as big of a deal; however if you have the tools and the time replace them both.
Old Nov 17, 2004 | 09:56 PM
KayOs's Avatar
Highly recommended that you use OEM pieces only. Good luck.
Old Nov 18, 2004 | 08:19 AM
AssPenny's Avatar
Default Re: Do I need new Pilot & Release bearing with ACT clutch install? (KayOs)
I just recently purchased an ACT HDSS and it came with a pilot and release bearing in the kit along with an alignment tool. They looked good so I used thouse. No complaints so far.
Old Aug 5, 2006 | 11:39 PM
Whorehey Nighten's Avatar
just got my fidanza flywheel and at clutch it seems like the act pilot bearing is too large for the fidanza flywheel.......is it possible they sent the wrong bearing
Old Aug 6, 2006 | 08:21 AM
88 rex's Avatar
Default Re: Do I need new Pilot & Release bearing with ACT clutch install? (9WON4)
Definitely change the pilot bearing. It's probably the cheapest bearing on a honda. It's also not that hard to hammer out and tap back in.
adam00
Aug 15, 2008 09:33 AM
b18c eJ1
Mar 17, 2007 12:25 AM
MechEng
Apr 1, 2003 03:45 PM
mr_mbuna
Dec 4, 2002 04:04 AM
Night Kid
Nov 8, 2001 01:53 AM
