oil on spark plug, on top of cylindar
Old Nov 17, 2004 | 01:34 PM
JDM-EJ1's Avatar
Default oil on spark plug, on top of cylindar
I just went out to check my oil, and I noticed that a little oil was coming out of the far right cylindar. I pulled the spark plug and noticed a small amount of oil on the bottom of the plug. What is causing this? Can this damage my car?
Old Nov 17, 2004 | 01:39 PM
=GAME='s Avatar
Default Re: oil on spark plug, on top of cylindar (JDM-EJ1)
change the O rings under the valve cover.
Old Nov 17, 2004 | 01:40 PM
JDM-EJ1's Avatar
Default Re: oil on spark plug, on top of cylindar ([G][A][M][E])
And if I don't change the O rings, what could happen?
Old Nov 17, 2004 | 01:41 PM
=GAME='s Avatar
itll leak more oil down the spark plugs. it cost a few bucks each. just replace them.
Old Nov 17, 2004 | 01:42 PM
JDM-EJ1's Avatar
And what will that cause? Will I just burn more oil, and lose oil quicker?
Old Nov 17, 2004 | 01:58 PM
JDM-EJ1's Avatar
ttt
Old Nov 17, 2004 | 02:01 PM
hayabusa160's Avatar
it can cause the spark plugs to foul up if it leaks bad enough.
and you will lose some oil also
civiccpedx's Avatar
Default Re: oil on spark plug, on top of cylindar (hayabusa160)
the dealer sells them for pretty cheap, but i dont know i replaced mine and they still leak.
Old Nov 17, 2004 | 02:24 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: oil on spark plug, on top of cylindar (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote"> i replaced mine and they still leak.</TD></TR></TABLE>
then you did something wrong.
Old Nov 17, 2004 | 02:30 PM
lohatch's Avatar
if you have never taken your valve cover off then i think your car is ok. put the spark plug back in.
Old Nov 17, 2004 | 02:46 PM
JDM-EJ1's Avatar
Default Re: oil on spark plug, on top of cylindar (lohatch)
I have never removed my valve cover since I've owned the car. There is VERY little amount of oil around the far right cylindar. I also noticed when I pulled that spark plug a little peice of the rubber around the shaft was coming off...
Old Nov 17, 2004 | 04:02 PM
stripes777's Avatar
i had the same prob on my old motor. except i would have oil on top of the spark plug and in the cylinder part of the spark plug. anyways, head down to the local dealer and buy 4 of those spark plug "O" rings and get a new valve cover gasket. shouldnt be more than 20 bucks.
Old Nov 17, 2004 | 04:24 PM
StrokedPSI's Avatar
Default Re: (stripes777)
If you really don't want to get new o-rings, you can just got to pepboys and get some "blue" silicone gasket maker material. Pull the old rings, clean the oil off them and run a bead of the silicone around them before you put em' back. It's the cheap way out (I guess), I've done it before and it works very well. Also, when I replace anything with a gasket (water pump, thermostat housing valve cover gaskets, oil pan gasket) I use the stuff. I haven't ever dripped a drop from anything I've used it on.
Old Nov 17, 2004 | 05:08 PM
lohatch's Avatar
Default Re: (StrokedPSI)
the point here guys is that i dont think there is a problem at all. wipe off what little bit of oil there was and put it back in. maybe check it in a few days. if you fear oil leaking from your valve cover down into the spark plug hole then yes replace the O-ring, but from reading what youve posted i dont think you should be worried.
Old Nov 17, 2004 | 05:10 PM
StrokedPSI's Avatar
Default Re: (lohatch)
or do that
Old Nov 17, 2004 | 05:32 PM
blue2ksi's Avatar
replace the grommet... if not, your car will start misfiring
cjwang2
Sep 30, 2015 10:17 AM
EG6_978
Sep 13, 2008 02:37 PM
premo_si
Jan 23, 2008 08:57 PM
fjt
Nov 23, 2004 08:52 AM
NickR
May 15, 2004 11:22 AM
