suspension advice
i had my illumina's on neuspeeds race for a while now and i need to retire the set up. im thinking of keeping my neuspeeds (i like the high spring rate of them) and im considering getting koni "reds". I was also thinking about AGX's but im not too sure how much they match up against the springs that i have.
Can anyone tell me what size the front sway bar is for my car?..i was thinking about also getting the skunk2 21 mm rear sway bar to even out my suspension..i hear that you must have a larger front sway bar than the rear to reduce oversteer..if that's the case i would settle for a GSR rear sway bar but i hear that it needs some modifications to be installed in my car. give me some enlightenment.
my car:
1995 civic ex coupe
my car:
1995 civic ex coupe
You're front sway-bar's prob'ly 21mm. I got a Neuspeed rear sway-bar (19mm,
I think), but you'll have to buy control arms also if your car's not set-up/doesn't
have one already. I have a '95 delsol Si (SOHC Vtec), so I'm assuming your
engine/chassis setup's like mine.
murderedrsx
Sep 27, 2011 10:51 PM
