BLOODY RUSTED SCREWS`!!!!
Old Nov 17, 2004 | 10:41 AM
kevinoneill's Avatar
Default BLOODY RUSTED SCREWS`!!!!
So its time to take of the cat...yeah i thought so anyway...
actually one end of smooth as butter...but the other...right...might as well be welded...heat shield too...
figured ok well i'll just take half the bloody exhaust of, so i went to the rear of the car take it off there....same type of bolts taht came of easy so it looked promising...but NOPE
Old Nov 17, 2004 | 11:28 AM
Default Re: BLOODY RUSTED SCREWS`!!!! (issues4)
wow the car sounds like *** with the car detached...
Old Nov 17, 2004 | 02:33 PM
Kataku2K3's Avatar
Are they just too tight and you can't get any leverage on the rachet or are they starting to strip? If it's just too tight and you haven't tried it already get a bar that you can slip over the rachet's handle and use as a breaker bar (if you also have the room). If they're starting to strip then what I normally do is try to pound on a socket with a hammer (in your case use a 13mm or 1/2 inch). That will probably be really hard since you've got to work upsidedown with an exhaust that can move when you hit it. If you can get the socket on a lot of time you can break those bolts loose but if that doesn't work then Scott and I hormally just weld a bar onto the bolt head (this will break them loose most of the time but sometimes you also just shear the head off). I'd also recommend putting the other header to cat bolt that you've already taken out back in until you get the other side loose.
I guess your last option if you really want it off is to cut it off!!!! Got a plasma cutter handy? Good Luck
Old Nov 17, 2004 | 04:28 PM
darkd1gt's Avatar
Default Re: BLOODY RUSTED SCREWS`!!!! (Kataku2K3)
yeah man i agree go to muffler shop and get them to heat them up and off that is the best cheapest way to go
jhof_wagon
Jun 29, 2012 11:26 AM
MelJ
Suspension & Brakes
Nov 7, 2010 11:48 AM
EatMyVTEC :]
Oct 18, 2010 01:44 PM
lil' murk
41
Dec 2, 2005 02:26 PM
RACEPAK
Oct 7, 2005 11:08 AM
