Car Safe to Break In??
Old Nov 17, 2004 | 10:10 AM
1BadCvC's Avatar
Default Car Safe to Break In??
Instead of breaking my motor in on the dyno im gonna put 700 or so mi. on it then tune it. The setup is a b18c bored to 85mm with JE 12:1 pistons, i have cam gears and a FPR along with a EGT gauge to keep a close eye on the A/F. Im wonding if it would be possible to perform a safe break-in along with being descently tuned? thanks
Old Nov 17, 2004 | 10:36 AM
drdisco69's Avatar
Default Re: Car Safe to Break In?? (1BadCvC)
Meh, the egt can only do so much in keeping track of AF ratios. It's possible, just back off the timing and be a little generous with the fuel, but why are you breaking it in on the street and not on the dyno? If you're going there anyway, it's the pefect time to do it.
Old Nov 17, 2004 | 10:45 AM
1BadCvC's Avatar
Default Re: Car Safe to Break In?? (drdisco69)
idk, guess bc ive had so many problems. im weary of the high rpms that it would have to run at on the dyno.
Old Nov 17, 2004 | 11:03 AM
drdisco69's Avatar
It's either going to break or it's not. Waiting isn't going to make it any stronger at high rpms. To get the rings to seal, you need to generate cylinder pressure, and the best way to do that in a controlled manner is a dyno. And the same procedure you use to break it in is the way you tune it:
50% throttle through 50% rpm range
60% through 60% rpms
70% through 70%
continue until you are at 100% throttle to redline. All this time you are watching AF and EGT and tuning as needed. This procedure also puts a load on the rings and breaks them in, ensuring a good seal and reducing blowby.
Old Nov 17, 2004 | 11:10 AM
1BadCvC's Avatar
Alright you talked me into it Thats the break-in im goin with anyhow so may as well do it on the dyno. ill just make sure it starts up fine b4 i haul it out of town...all or nothin i guess, thanks for the advice.
sowellman88011
15
Mar 24, 2015 06:23 PM
d16dcoe45
Jan 16, 2007 11:53 AM
JerKeK9
Aug 6, 2004 08:59 PM
2000vsm
Feb 16, 2004 01:27 AM
UA6 BALLER STATUS
Oct 26, 2003 06:38 PM
