what is vtecH?
okay guys ive been hearing SOOOO many people talking about VTECH....
what is it? what does it do? etc? etc??
how does it differ from VTEC or i-vtec?
-=Z
(haha and besides it being a phone company
[Modified by IM ALL SHO, 7:13 AM 12/31/2001]
-=Z
) [Modified by IM ALL SHO, 7:13 AM 12/31/2001]
Ok, its VTEC and it stands for Variable vavle Timing Elctronic Control. If you've ever seen a regular cam you know there there is a lob for each valve. VTEC cams have one lobe for each valve then a third lob that is bigger. When then engine is at low rpms, the primary lobs are working the valves. When your engine reaches VTEC range, there is a hydrolic pin that locks the third rocker arm into the rocker arm for the primaries. Once that has happend, your engine is now running off the third lob of the cam. This is VTEC.
i-VTEC is what the new generation of Honda engines have. The third lob is still there, however the "i" stands for "intelegence." The new engines can electronically control the intake cams timing via an adjustable cam gear.
-Steve
-Steve
VTEK makes video microscopes. See, I have proof... http://cti-vtek.com/
this has got out of hand!
i was just hoping people would come here and recognize the sarcasm and know that its really VTEC... VTEC VTEC.....
VTEC not vtech, if you know anything about a hond motor your know what the hell it is
and if you would have read the other post i have posted a couple days prior to yours, you would have seen this thread was sarcasm and i was just being a dick to a fellow H-T member who refered to it as VTECH...
people like you make me say F VTEC!
i should give you a rice ticket for having EK9 in your name...
Guest
Posts: n/a
dont flame his *** if he is trying to learn. and read the above posts it was explained several times
https://honda-tech.com/zeroforum?cmd...nnounce&id=1#9
Correct me if I am wrong, but isnt it Variable Valve Timing and Electronic Lift Control? They only used VTEC because it sounds better than VVTELC.
Yes, but if I had told that to someone who didn't even know how to spell VTEC, I would have gotten "Wouldn't that be VVTELC?" as a reply. :D
-Steve
