What does a Hondata Intake Manifold Gasket do? maintance questions ?
hey i was just wondering if there were gains from an Intake manifold gasket
My car has come to around 130K and im lookin for places to restore lost Power this is what ive done so far
Sparkplugs
Distributor Cap + rotor
Fuel filter ASAP
new grounds
reset ECU
Oil change
what else would be a good idea
Sparkplugs
Fuel filter ASAP
new grounds
reset ECU
Oil change
The hondata intake manifold gasket goes between the intake mani and the head. Its a plastic composite material that is supposed to lower intake temps. If you already have the manifold or the head off, then go ahead and get one. otherwise, i wouldent go out of my way.
Also, if you are wanting to do maintanence on the car, get a valve adjustment, check your timing belt for wear. How many miles are on your car and has it had a full tune-up? plug wires?? water pump ? fluid flush and bleed? etc.
i believe you can get decent gains if you combine the intake manifold gasket with the coolant bypass mod.. i felt a nice gain after doing both of them, especially at night when the air is cooler.
Modified by oNeMoBB1 at 11:05 AM 11/17/2004
so did you "feel" a nice gain? or did you get on a dyno and see an actual gain over the powerband ?
Butt-dynos dont count
haha.. ur a funny guy. well thats what i felt butt i don't know what a dyno would feel. i should have a pretty worthwhile dyno coming up by the end of the year with my nextgear thermoshield gasket/coolantbypass mod and custom exhaust setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AO »</TD></TR><TR><TD CLASS="quote">Holy **** check your timing belt.
Could save you $1,000+ in repairs if you just do it now. </TD></TR></TABLE>
the timing belt was changed at 90K miles? should i still check it?
Would it be agood idea to get teh valve adjustment at the dealership or what?
SAme with flushes? or would a regular meinike be able to do this?
do them yourself smart guy
Not only will you save an ASSLOAD on labor and junk that a honda stealership would charge, but you also gain the basic knowledge of changing all your fluids.
Just make sure you got a backup car or a buddy that is willing to take you to the dealership or your local auto parts store for anything you may need during this fun.
Let the dealership do the valve adjustment if you have no idea what you are doing. Are you somewhat car friendly? or are you to afraid/to lazy to do it your self? If you dont think you can handle changing the fluids on your own, let the dealership do it all with OEM fluids and what not. mineke will put some weird *** no name brand tranny fluid and what have you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">do them yourself smart guy
Let the dealership do the valve adjustment if you have no idea what you are doing. Are you somewhat car friendly? or are you to afraid/to lazy to do it your self? If you dont think you can handle changing the fluids on your own, let the dealership do it all with OEM fluids and what not. mineke will put some weird *** no name brand tranny fluid and what have you.</TD></TR></TABLE>
thanks for the help: I would do the jobs by myself, but I dont really know wehre to turn, and it might be hard for me to get rides everywhere. Besides that, i am defently eager to learn and peform the maintinance myself, but rn't sure i have the resources to get allt he OEM fluids/ Tools that i would need. How long of a project is the Valve adjustment, and how hard (1-10) would you think it might be?
Could u list all the fluids that need to be changed
EDIT: just found DIY valve adjustment
get the helms for your car.....that will answer EVERY question you will ever have. Its the best cash you could spend when looking to maintain your vehicle.
alright... anyone have the cd they wanna burn me? ill pay
back to valve adjustment:
What size feeler do u need for each cam? .006, .007, .008???
would this be a good feeler guage , because i do not have one
http://cgi.ebay.com/ws/eBayISA...&rd=1
For valve adjustment, Eaither home make that tool or go buy the snap-on tool. You will also need a feeler gauge, some basic sockets and and wrenches (you might want to let the dealership do this one) You would also probably need a new valve cover gasket and possibly some hondabond.
For the fluid changes, that **** is easy man.
CAUTION!!LET THE CAR COOL FOR AT LEAST 1-2 HRS BEFORE WORKING ON IT!!!
You will need, 5 Quarts of Oil, OEM Honda filter of your choice (S2000, HAMP, whatever) and again basic wrench to get the drain bolt off, and something to catch the oil in. An oil change should be pretty self explanitory. Just make sure to oil up the seal on the new oil filter, and a little bit more than hand tight is fine. Put the drain bolt back in and fill her up. be careful when pulling the drain bolt on the oilpan, the pressure will launch the oil a good distance, causing you to make a nice mess if you dont have the oil catch in the right spot. Have rags handy.
If you just had your Tbelt replaced, they should have done all the fluids, so no need for a coolant or tranny fluid flush. Just change your oil, get some new NGK or OEM spark plug wires, and you should be good.
Remeber, you can get any sort of part/gasket anything from the honda dealership if you get in a bind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">For valve adjustment, Eaither home make that tool or go buy the snap-on tool. You will also need a feeler gauge, some basic sockets and and wrenches (you might want to let the dealership do this one) You would also probably need a new valve cover gasket and possibly some hondabond.
Remeber, you can get any sort of part/gasket anything from the honda dealership if you get in a bind. </TD></TR></TABLE>
i did an oil change bout 1000K miles ago, i know hwo to do that ****... sparkplugs changed 100 miles ago
I think these r the next maintanence i wil do:
1: fuel filter change
2: tranny fluid flush (snycromesh)
3. valve adjustment
I was thinkin bout repainting my valve cover, so i guess it would be a good time... Maybe i wil buy an additional, then sell the existing one all Stripped and ready for more paint
3. valve adjustment
well then there you have it. have a good time, make a post if you get stuck
Also, i had said spark plug wires, no where in any of your posts does it say you have changed those.
well they were changed.. they're NGK blues, im not really sure the milege on them, but when i changd the distrib cap+ rotor , i checkd to make sure they were decnet
and when i changed the park plugs i checekd them and they looked mint
can these go bad?
can these go bad?
b16vtecsol
27
Dec 16, 2003 12:11 PM
