dirty ass manifold... sea foam???
Old Nov 17, 2004 | 07:38 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default dirty *** manifold... sea foam???
my poor little Z1 is beggin to be abused, so i got in my 450's the other day, and im going to be turbo'ing it... but when i pulled the injectors, this is what came out.. lol
what do you guys think? sea foam?
Old Nov 17, 2004 | 08:02 AM
mafioso102's Avatar
New User
Default Re: dirty *** manifold... sea foam??? (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
what do you guys think? sea foam?</TD></TR></TABLE>
couldn't hurt
Old Nov 17, 2004 | 08:04 AM
93CivicSI's Avatar
Follow the instructions - but...... a couple of cans...
Old Nov 17, 2004 | 08:36 AM
menkio's Avatar
Default Re: dirty *** manifold... sea foam??? (93CivicSI)
dood.. clean your freaking tb/intake/penlum.. replace the gasket with a an-r. hondata. etc... thats gross
Old Nov 17, 2004 | 08:40 AM
lohatch's Avatar
wipe all that stuff down reassemble. good to go
Old Nov 17, 2004 | 08:43 AM
Archidictus's Avatar
Unceasing Measure
That's some sick ****, dude. Clean it as best you can before you seafoam it.
Old Nov 17, 2004 | 08:48 AM
PH3593A's Avatar
Are you filling up at Pemex?
Seafoam is awesome. I got a lawn edger started after cleaning with it with Seafoam, it hadn't run in years.
Old Nov 17, 2004 | 08:53 AM
nonsense's Avatar
I'd pull the mani off and clean it first, then seafoam. Are you running a catch can by any chance? How's your PCV valve? Looks like too much oil vapor is getting sucked in
Old Nov 17, 2004 | 09:58 AM
Built B16A's Avatar
Default Re: dirty *** manifold... sea foam??? (nonsense)
bone stock VX with 230K miles.. never touched the PCV valve, just spark plugs and cap and rotor.. nothing drastic.
but, i think im going to take my chances.. im due for an oil change anyhow, i think im gunna sea foam it, and then change the oil after a nice little run.
Old Nov 17, 2004 | 11:28 AM
Falqon's Avatar
dude, change the pcv valve, they're cheap. I'm hoping water pump and timing belt wasn't on the "changed" list because they're irrelevant?
Old Nov 17, 2004 | 11:34 AM
Built B16A's Avatar
Default Re: dirty *** manifold... sea foam??? (Falqon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon &raquo;</TD></TR><TR><TD CLASS="quote">dude, change the pcv valve, they're cheap. I'm hoping water pump and timing belt wasn't on the "changed" list because they're irrelevant?</TD></TR></TABLE>
hahah.. yeah, i think im going to make a write up soon.. i just got done sea foam'in it.. and i think things are good.. but i wanna get a pic of the oil comming out.. but as of right now.. things look good.
lets see.
sea foam w/ manifold flush (deep creep)
plugs
cap
rotor
and now im thinking about fuel filter and the PCV.
after i change the oil.. maybe later today or tomorrow i'll post it up. but things look good.
(and yes, the waterpump and timming belt were changed on time)
Old Nov 18, 2004 | 02:29 AM
Built B16A's Avatar
well.. i did sea foam it after all... and i created another thread..
if you care to take a look.. here is the link.
https://honda-tech.com/zerothread?id=1059690
Old Nov 18, 2004 | 02:58 AM
VTECMaster's Avatar
my manifold looked exactly the same way... i throwed it in w waterbath and added some engine cleaner, floor cleaner... everything i could find....
worked great
Old Nov 18, 2004 | 09:18 AM
HATCHIT's Avatar
Default Re: dirty *** manifold... sea foam??? (mafioso102)
yikes.
Old Nov 18, 2004 | 10:07 AM
Frozen E's Avatar
H-T White Ops
My injectors looked like that too when I pulled them about a week or so ago. B16A2 with 57,000 miles on it. Nasty ****. Didn't know what the hell it was but I see some seafoam in my future. That ****'s nasty.
Old Nov 18, 2004 | 10:38 AM
EK k kay's Avatar
Default Re: (IslandSi)
Pull the manifold off and clean it out with carb cleaner. It'll look brand new.
Old Nov 18, 2004 | 10:40 AM
Built B16A's Avatar
Default Re: (chowmien)
i didn't want to buy another intake manifold gasket.
and thats alot of work, the sea foam took like 15 mins.
r3v da t3g
Nov 2, 2014 11:24 AM
boostincoupe
Jul 14, 2006 10:05 PM
idriveadelsol7
Dec 8, 2005 11:29 PM
menkio
Welding / Fabrication
22
Nov 24, 2004 04:10 AM
LAQUALO101
Sep 7, 2004 02:49 PM
