Max bore on del sol TB.....
Old Nov 17, 2004 | 07:23 AM
jarel's Avatar
Default Max bore on del sol TB.....
I've searched around and some people say 64mm. What is the max bore size that you can go on a B16 Del Sol TB without the walls becoming too fragile?? Anyone?
Old Nov 17, 2004 | 10:13 AM
hybrid_vtec's Avatar
Default Re: Max bore on del sol TB..... (jarelee)
between 62 and 64mm
Old Nov 17, 2004 | 04:29 PM
XxslayerxX's Avatar
62mm for the Del sol VTEC. I have one and i bought a gsr tb and had it bored to 64. Since the size at the butterfly is 60mm on that one. The Del sol VTEC's tb is only 58mm at the butterfly.
Old Nov 17, 2004 | 05:32 PM
G U E C O's Avatar
Default Re: (XxslayerxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxslayerxX &raquo;</TD></TR><TR><TD CLASS="quote">62mm for the Del sol VTEC. I have one and i bought a gsr tb and had it bored to 64. Since the size at the butterfly is 60mm on that one. The Del sol VTEC's tb is only 58mm at the butterfly.</TD></TR></TABLE>
well dont u change the butterfly anyways? im sure spaceball changes them
Old Nov 17, 2004 | 05:43 PM
XxslayerxX's Avatar
yeah you do. Im just saying stock for a Del sol VTEC is 58mm so when you bore it out you can only bore it 4mm over the stock side. So it would only be 62mm. If you want one to beb bored to 64 find a GSR or B16a2 TB.
Old Nov 17, 2004 | 06:14 PM
jarel's Avatar
thanks for the info guys
9DcurlyS4
Northwest
Mar 25, 2011 10:39 PM
pensch
Mar 22, 2011 11:06 PM
VR4ownzU
12
Apr 16, 2007 10:59 AM
Spool Me Up
Sep 13, 2003 03:53 PM
YellowCivic95
Jun 2, 2002 04:51 PM
