Interior light comes on when taking hard left turns. 93 Del sol
Anyone have this problem? It seems like it happens everytime I take a left turn hard. Almost like the door is moving away from the switch and activating the light. Also if I hit hard bumps the light will go on. The door is closed and does not have any movement so I doubt it is that. Maybe a bad ground?
Any thoughts?
Any thoughts?
commom problem
when you make the turn, your door is slightly comming off the sensor in the doorjam, reason why it only happens one a left turn and not a right. It would be the passengers side.
oh yeah and SEARCH MOTHERFAWKER!!!!!!!!!!!!!
j/p
https://honda-tech.com/zerothread?id=577126
j/phttps://honda-tech.com/zerothread?id=577126
Yeah I tried to search but did not know what to really put in for search terms. I will check out the screws. I figured it was something with the right door, IE only goes on with left turns.
mine does the same thing in turns and also when i am going out of my driveway which is at a huge slant. I always thought it was the body/frame flex?
I used to have the same problem. What I did was open the door and move the door latch in about a 1/4 of an inch. Problem solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">make sure your wiener isnt caught in the door, or any other items...and is closed all they way</TD></TR></TABLE>
yeah check that!!! i hate it when my dick gets caught in the door
huh i never get it when i go around corners. but when i go in to parking lots at an angle when its real steep my dome light turns on. i always just thought it was a bad ground.
Yup!!...mine did the same thing. I took off the rubber covers and put some paper in the tip for a temp fix. This is only like 13 bucks at the dealership. Just replace it.
Sonia's Driver
Jan 20, 2011 12:57 PM
theqballer
19
Jan 25, 2008 11:59 AM
