i turboed my sohc
Correct me if I'm wrong, but if it's a t25 from a dsm, then the factory setting is 10psi (then the eclipse/talon's ecu picks it up to something like 12psi). Wouldn't you need to change the spring on the wastegate to take boost below 10psi?
Not totally sure about this...somebody clarify please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX »</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong, but if it's a t25 from a dsm, then the factory setting is 10psi (then the eclipse/talon's ecu picks it up to something like 12psi). Wouldn't you need to change the spring on the wastegate to take boost below 10psi?
Yes..you're right
Turbonetics and garret make different springs for the T25..
You could buy from them or cut the spring insde the actuator..
I dont know about this guy though..He didnt givge a good description at all..
</TD></TR></TABLE>Yes..you're right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">
Yes..you're right
Well...since i was right, what do i win?
Yes..you're right
</TD></TR></TABLE>Well...since i was right, what do i win?
the other day he was rambling about an intake chip. Don't listen to this damn 04' member he has no t25, he prolly heard it on super2nr tv or something.
How about a stale cookie?
</TD></TR></TABLE>How about a stale cookie?
well you can shim the waste gate arm to lower your boost but ya 8 psi is fine as long as you have some sort of decent fuel manegment if you want to be on the safe side you can retard your timing a little and run the highist octane fuel you can get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchMo »</TD></TR><TR><TD CLASS="quote">the other day he was rambling about an intake chip. Don't listen to this damn 04' member he has no t25, he prolly heard it on super2nr tv or something.</TD></TR></TABLE>
LOL
LOL
Oh...lol.
Oh...lol.
AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH
no, wait...
edit: ¿¿¿¿his post rating already got pwn3d, and he only has 9 posts????
no, wait...
