exedy stage 1 or stage 2 clutch
Old Nov 16, 2004 | 11:57 PM
mprelude's Avatar
Default exedy stage 1 or stage 2 clutch
should i buy exedy stage 1 or stage 2 which one is better.
Old Nov 17, 2004 | 05:04 AM
LowFlyin''s Avatar
Depends on the application.
Old Nov 17, 2004 | 09:31 AM
Boarderx192's Avatar
Default Re: (LowFlyin')
How are these clutches? I was think about getting a "stage 1" because It offers the upgrade torque capacity and it also retains the normal street drivability. Who uses these and how do you like them so far?
Old Nov 17, 2004 | 10:35 AM
mprelude's Avatar
Default Re: (Boarderx192)
well right now i have an exedy stage 1 in my car its pretty good though but i was wondering if i should buy stage 2 for the 4 gen prelude.
Old Nov 17, 2004 | 10:38 AM
AndyD's Avatar
Default Re: (mprelude)
How much HP is your car producing??
Do you only daily drive?? Drag strip?? Road race??
Old Nov 17, 2004 | 10:52 AM
mprelude's Avatar
Default Re: (AndyD)
well my car is probably pruducing around 250 hp. but i do drive alot in street than drag but i use to drag but i have to wait next sumer for that.
Old Nov 17, 2004 | 10:59 AM
98TypeSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mprelude &raquo;</TD></TR><TR><TD CLASS="quote">..............well right now i have an exedy stage 1 in my car its pretty good though but i was wondering if i should buy stage 2 for the 4 gen prelude.
...........................well my car is probably pruducing around 250 hp. but i do drive alot in street than drag but i use to drag but i have to wait next sumer for that.</TD></TR></TABLE>
So you got a stock 4th gen prelude putting down 250 hp huh ?
Old Nov 17, 2004 | 11:03 AM
mprelude's Avatar
Default Re: (98TypeSH)
no i got mods in my car but im just saying that i produce around 250 hp maybe less
Old Nov 17, 2004 | 11:11 AM
98TypeSH's Avatar
stage 2 should be fine for a daily driver/ weekend warrior.
I myself went with a unsprung puck disc.
Old Nov 17, 2004 | 11:12 AM
AndyD's Avatar
Based on the info you provided us, I've drawn one conclusion. You have more money than you know what to do with.
Based on what you use your car for, you should use an OEM Exedy clutch kit. You don't need anything else.
Since you already have a Stage 1, just keep it.
Old Nov 17, 2004 | 11:20 AM
WRS Motorsports's Avatar
Default Re: exedy stage 1 or stage 2 clutch (mprelude)
If your car is daily driven the Stage 1 is perfect, if you plan to make a habbit of going to the drag strip the stage 2 will last longer.
Hawkze_2.3's Avatar
What mods do you have that you think you have 250 hp? I/H/E doesn't add 50 hp...
If you do in fact have 250 hp, I'd go with the stage 2. I have heard many good things about it's driveability and I'm sure it will hold the amount of power you have.
Old Nov 17, 2004 | 11:44 AM
Default Re: (Hawkze_2.3)
Which stage 2? I thought that there were 2 differenet stage 2's?
Old Nov 17, 2004 | 11:47 AM
Hawkze_2.3's Avatar
Yeah, there's a thin and a thick version of the disc (3-puck sprung). The thin is obviously lighter, but doesn't withstand heat as well. For some reason they say use the thin only for the track??
The thicker version is just that and it holds up to heat better and they reccomend it over the thin for street use.
I got the thin one, so we'll see....
Old Nov 17, 2004 | 02:01 PM
LowFlyin''s Avatar
So, when you guys are saying 'stage 1' are you talking about the Exedy Organic Disc?
Old Nov 17, 2004 | 02:11 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mprelude &raquo;</TD></TR><TR><TD CLASS="quote">well my car is probably pruducing around 250 hp. but i do drive alot in street than drag but i use to drag but i have to wait next sumer for that.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mprelude &raquo;</TD></TR><TR><TD CLASS="quote">no i got mods in my car but im just saying that i produce around 250 hp maybe less</TD></TR></TABLE>
what type of mods? My old street nitrous setup made well over 250 whp. I was using nippon denso clutch stage 1 clutch which is basically the samething. Over 2years clutch is still good. I have a more beefy setup now so I using stage 2. If its daily driven I would say stick with the stage 1, unless you honestly have 250whp which is not easy to pull off. Just my 2cent
Old Nov 17, 2004 | 05:35 PM
mprelude's Avatar
Default Re: (md23vtec)
ya ima just stay with the stage 1. Thanx guys
Old Nov 17, 2004 | 05:45 PM
eluder33's Avatar
it better to get a "weaker" clutch than a stronger one due to the grabing abilities of each and the harder it grabs the more likely you are to break axles and trannys, I'd rather have a clutch go than a tranny, thats just me though.
Dubs13
Sep 11, 2010 05:52 PM
Chipped B6
16
Feb 24, 2009 09:11 AM
RGK500
Oct 5, 2006 10:21 PM
warwagon
Mar 16, 2003 05:07 PM
