can you use a LS timing belt w/ GSR water pump?
Old Nov 16, 2004 | 10:18 PM
1slowcrx's Avatar
Default can you use a LS timing belt w/ GSR water pump?
i'm putting a ls/vtec together,i normally use a 22teeth vtec water pump along with a gsr timing belt,but what i wanna know is can you use a 22teeth water pump with a LS timing belt?would it be too lose or too tight?is there going to be any problems?
Old Nov 16, 2004 | 10:39 PM
mmuller's Avatar
Mad Scientist
Default Re: can you use a LS timing belt w/ GSR water pump? (1slowcrx)
no you cant use the ls belt with a 22t water pump
Old Nov 16, 2004 | 10:49 PM
1slowcrx's Avatar
Default Re: can you use a LS timing belt w/ GSR water pump? (mmuller)
reason being?
Old Nov 17, 2004 | 12:38 AM
Kataku2K3's Avatar
because it will be too tight, it's intended have the same amount of slack BUT with a nonVTEC 17T pump. I have seen some people (retards) put nonVTEC water pumps on VTEC motors, still using a VTEC timing belt. Since you'll never be able to get all the slack out of it does have a good chance of slipping but it will still run. (don't do this, i'm just giving an example)
Old Nov 17, 2004 | 12:48 PM
spyz34's Avatar
Default Re: can you use a LS timing belt w/ GSR water pump? (Kataku2K3)
I know you cant do non-vtec on vtec, but can you put a gsr oil and water pump onto a b18b?
Old Nov 17, 2004 | 01:00 PM
Kataku2K3's Avatar
Default Re: can you use a LS timing belt w/ GSR water pump? (spyz34)
Yup, and that's actually what you "should" do when building an LS/CRVTEC, you just use a GSR/ITR timing belt. We do this on all the motors we build.
Old Nov 17, 2004 | 01:46 PM
spyz34's Avatar
actually im just goin to run a LS-Turbo. Will it still work?
Old Nov 17, 2004 | 02:16 PM
Kataku2K3's Avatar
Yea, if you're reving your motor higher than the stock 6800rpm I would definately swap the water pump, if it's not much higher the VTEC one will still work but it is intended for higher rpm usage. I don't know what year motor you're working with but most late model oil pumps are all the same nonVTEC or VTEC so it really doesn't matter. While you have everything off I would just buy a GSR/ITR oil pump (even though they all should be the same) and put it on there.
Old Nov 17, 2004 | 03:24 PM
Boofster's Avatar
No you cant use it. The gsr water pump has more teeth so your timing will be way off.
thirsk66
10
May 22, 2013 02:26 PM
Justintegra
Apr 20, 2008 12:46 PM
lsvtechatch04
May 8, 2004 03:20 AM
275Performance
Jan 4, 2003 04:45 PM
ILOVEGIRLS
Sep 30, 2002 11:07 PM
