Installed Apexi WS II on hatch with S.T. sway bars. Not to friendly.
Old Nov 16, 2004 | 09:46 PM
Spins's Avatar
Default Installed Apexi WS II on hatch with S.T. sway bars. Not to friendly.
Installed exhaust. I had to remove the rear sway bar end links inorder to get the can over the suspension. It bolted up fine after that. The front is another story. The cat is now lying on the front sway bar. I tried to loosen the bolts and readjust. But it's still no good. I've got rattles and vibrations. Got to do something tomorrow to fix this. Maybe add washers to the front sway bar mounts to lower sway bar.
I will be having a b18c installed soon. Probably add a test pipe. This should clear.
The exhaust itself is quiet. Just what I wanted. The paint or powercoating on the pipes scratches off easily. The kit came with all new bolts,washers and gaskets.
talkJDM
Sep 13, 2009 05:55 PM
hondapimp125
Jan 9, 2009 10:30 AM
Shizznaz
Suspension & Brakes
Jul 20, 2005 04:20 PM
importboi22
23
May 4, 2004 03:34 PM
wdskuk
Sep 5, 2003 10:47 AM
