axle question
Old Nov 16, 2004 | 08:17 PM
b16crx0062004's Avatar
Default axle question
i have a b16a1 and i need to know what axles do i use? da axles? are all axles the same for "b" transmission's cable/hydro?
thanks
Old Nov 16, 2004 | 08:42 PM
JapJunkie's Avatar
Default Re: axle question (b16crx0062004)
DA
Old Nov 16, 2004 | 08:45 PM
b17hybrid's Avatar
I have a b17 in a 90 civic hatch. I'm just using 90-93 integra axles. Works fine for me. I'm not sure about other years though. Usually, if you have an 88-91 civic/crx, you would use 90-93 integra axles. Of course, it depends on what kind of intermediate shaft you are using. The JDM and USDM intermediate shaft are NOT the same length. I'm not sure which is longer, but I know for sure that if you use the integra intermediate shaft, you would use the integra axles and vice versa.
Old Nov 16, 2004 | 08:57 PM
mrspeaker's Avatar
Default Re: axle question (b17hybrid)
they're right .. use 90-93 axles..
Make sure they're not abs though, because the abs axles bind up when you try to turn..
Old Nov 16, 2004 | 09:15 PM
RC_SKUBY's Avatar
If you have a std hatch you will not be able to use the 90-93 teg axles unless you change out your hubs. any other hatch will work fine
Old Nov 17, 2004 | 06:13 PM
Default Re: axle question (skuby_do)
thanks
88 civic ef
Apr 19, 2006 03:01 PM
.Grimace
Sep 23, 2005 12:38 AM
mr-mister
Sep 3, 2005 10:05 AM
B20 BEAST
Apr 30, 2003 05:12 AM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
