LS Turbo B18B1 CRX Si Build Up Suggestions
Old Nov 16, 2004 | 08:05 PM
The DX Rex's Avatar
Default LS Turbo B18B1 CRX Si Build Up Suggestions
this is my set up, just got the car a couple of weeks ago:
CRX Si 1988
B18B1 Motor out of a 96 LS with about 90,000 miles
90-93 Tranny, Dizzy, Throttle Body, ECU
Stock Cat 2.25 cat back exhaust
now the turbo kit i have is the Apexi Ball Bearing turbo kit with the IHI ball bearing turbo. i have a front mount intercooler, bov, greddy turbo timer.
list of the stuff i am buying before i put the turbo kit on
- new clutch,prolly exedy stage 1 or 2
- fidanza 7.5 lb flywheel
- Apexi SAFC 2
- low compression headgasket
- blockguard
- 3 in exhaust
- darkstarsracing crossmember/traction bar
- drag radials on 14 in steelies
now what else can i do or get to safely run 10 psi without worrying at all. i really dont want to buy pistons because all i found were 9.0:1 pistons but the stock compression is 9.2:1 so i really dont wanna do that.
would converting to obd1 and runnin an obd1 teg ecu make any big difference before and after turbod?
Old Nov 16, 2004 | 08:22 PM
mrspeaker's Avatar
Default Re: LS Turbo B18B1 CRX Si Build Up Suggestions (nyhustla2k)
you said you have 90-93 dizzy.ecu..etc..
Are you sure you dont have obd1 already because the 90-91 teg is obd0 but the 92-93 is obd1 ..
And I would only trust the safc for low boost because the thing takes away fuel and you dont want that to happen when you have a turbo pushing more air.
Look into uberdata 0bd1----turboedit for obd0....Its free..all you have to buy is the chip burner...Its similar to hondata without the price
..And when you get the turbo set-up on..the first thing you should do is have it towed to a reputable tuner..tuning is costly but its worth it..
Old Nov 16, 2004 | 08:25 PM
The DX Rex's Avatar
i also have an FMU as well
well if i converted to obd1 id obvisouly change the dizzy and ecu
Old Nov 16, 2004 | 08:26 PM
The DX Rex's Avatar
yea i also have someone that is excellent in tuning so having it tuned properly is not an issue
silvc86
Honda Civic (2006 - 2015)
Jun 15, 2010 08:24 PM
89crxsleeper
Jul 14, 2006 09:32 PM
95_red_dc
May 29, 2006 04:32 PM
IgniteTeg
36
May 8, 2004 02:45 PM
D16Z6racing
May 14, 2002 04:40 AM
