LS whp? post your numbers people!
Old Nov 16, 2004 | 07:44 PM
Ch3mik's Avatar
Default LS whp? post your numbers people!
I was wondering how much you guys have put down using an LS motor and if so what mods you have. ALL imput is appreciated.
Old Nov 16, 2004 | 07:50 PM
itsJDMyo's Avatar
Default Re: LS whp? post your numbers people! (_Chemik_)
bUmp
Old Nov 16, 2004 | 07:55 PM
boosted k20's Avatar
Default Re: LS whp? post your numbers people! (itsJDMyo)
i wish i knew my whp. will find out in a 2 months after i install some pistons.
My setup
AEM CAI
TSUDO 4-1 header
TSUDO N1 cat-back
MSD 6a and Blaster 2 coil
APEX-i SAFC
B&M FPR
CROWER 62403's with valvesprings and titanium retainers
soon: PR3 pistons => CR of 10.8:1
will get it dyno tuned as soon as them pistons are installed
Old Nov 16, 2004 | 08:26 PM
StyleTEG's Avatar
Default Re: LS whp? post your numbers people! (boosted k20)
165whp,
Crower 404s
DC 4-2-1
B18A head milled .018"
2.25" exhaust & testpipe
3" Intake
Greddy E-manage
155whp,
9.6:1 JDM B20B
LS IM
DC 4-2-1
3" Intake
Greddy E-mange
Old Nov 16, 2004 | 08:41 PM
JL's Avatar
JL
https://honda-tech.com/zerothread?id=978028
https://honda-tech.com/zerothread?id=926533
Old Nov 16, 2004 | 08:59 PM
Ch3mik's Avatar
Default Re: LS whp? post your numbers people! (StyleTEG)
damn. those are some good numbers. im asking this because i will be demoting to an LS . I currently have an allmotor LSVtec 183/136 untuned, but may be selling the motor to fund my next project. I plan on runnin the LS with AEBS intake mainfold, STR 65mm TB, 2.75" CAI,Greddy Stainless 4-2-1 Header, test pipe, GReddy SP2 exhaust on an NX wet 75shot. think Ill make 200whp?
Old Nov 16, 2004 | 09:04 PM
90 integra's Avatar
with that 75 shot yeah. raise the cp alittle bit not to much.thats what im thinking of doing.
Old Nov 16, 2004 | 09:05 PM
90 integra's Avatar
btw style teg what cp is on the first motor? any head work?is that all you did?nice numbers.
Old Nov 16, 2004 | 10:27 PM
StyleTEG's Avatar
Why get an AEBS manifold and 65mm TB with stock cams?
No headwork, I should have been roughly 9.5:1 with the first motor.
Nothing else done noteworthy.
Old Nov 17, 2004 | 10:18 AM
hybrid_vtec's Avatar
65mm? Why not just bore yours to 62 or 64mm for $100 through maxbore!
StyleTeg is right, you need bigger cams and/or higher compression!
Old Nov 17, 2004 | 09:42 PM
Ch3mik's Avatar
Default Re: LS whp? post your numbers people! (hybrid_vtec)
well. thats because those are the boltons i have on my current LSVtec with a 12:5 compression on CTR pistons on B18B bottom end. the only other choice I really have is B16 pistons but I dont want it that high with a 75 shot. and i dont wanna spend $$ on forged pistons to get the ratio I want cuz in that case ill just build another LSvtec to boost like I was plannin to. know what im sayin?
Old Nov 17, 2004 | 09:47 PM
StyleTEG's Avatar
The AEBS manifold isn't going to bolt up to an LS head then.
Go with a stock TB/IM
Old Nov 18, 2004 | 04:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Chemik_ &raquo;</TD></TR><TR><TD CLASS="quote">well. thats because those are the boltons i have on my current LSVtec with a 12:5 compression on CTR pistons on B18B bottom end. the only other choice I really have is B16 pistons but I dont want it that high with a 75 shot. and i dont wanna spend $$ on forged pistons to get the ratio I want cuz in that case ill just build another LSvtec to boost like I was plannin to. know what im sayin?
Keep the CTR's in and go allmotor with Big cams or you can use the B16 PR3's for N2O! You will yield 10.8:1 CR (Perfect for nitrous), assumming that the head isn't milled
Old Nov 18, 2004 | 08:54 AM
joboost13's Avatar
im putting in my jap spec b20b this weekend, mods will b exedy clutch, act prolite flywheel, and b16 tranny. Wana do a non vtec build up, but dont want 2 touch the bottom end sence it only has 20k on it. Its going 2 b great.
Old Nov 18, 2004 | 09:19 AM
Default Re: LS whp? post your numbers people! (joboost13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joboost13 &raquo;</TD></TR><TR><TD CLASS="quote">im putting in my jap spec b20b this weekend, mods will b exedy clutch, act prolite flywheel, and b16 tranny. Wana do a non vtec build up, but dont want 2 touch the bottom end sence it only has 20k on it. Its going 2 b great.</TD></TR></TABLE>
Sounds like a good start, keep us informed!
Old Nov 18, 2004 | 09:22 AM
joboost13's Avatar
i got a great deal on a pnp job, 650 wit a 10% off labor. Full port and polish and have the head shaved .30 2 bump up the cr. Job getting done by Ross racing hear in south florida, does any 1 know what my cr would b, i figured it around 9.5 or so.
Old Nov 18, 2004 | 09:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joboost13 &raquo;</TD></TR><TR><TD CLASS="quote">i got a great deal on a pnp job, 650 wit a 10% off labor. Full port and polish and have the head shaved .30 2 bump up the cr. Job getting done by Ross racing hear in south florida, does any 1 know what my cr would b, i figured it around 9.5 or so.</TD></TR></TABLE>
Talk to StyleTeg, I think he did the same and got 9.8:1!
Old Nov 18, 2004 | 10:08 AM
AllMotorDA9's Avatar
I have the same set-up, b20b, p&p head and milled .030, and skunk2 i/m and many other bolt-ons. We did a comp. check once we had it all in and running good, across the board it average around 210. Im guessing my comp. is around 9.5-9.6. I havent put the 404's in yet due to lack of money. So i just put some 94 ls cams in and it pulls the hardest up top around 6k, sucks becuase fuel cuts out at 6800, stupid rev limiter .
I should be posting about my set-up and how well its going just to keep all you LS/b20 non-vtec guys intrested.
Old Nov 18, 2004 | 02:58 PM
nonvtecallmotor's Avatar
Default Re: LS whp? post your numbers people! (OneSlowDA)
My new 2.0 nonvtec made 195/138 and went 12.12 @ 111. My old 2.0 nonvtec made 198/148 and went 12.48 @ 107 in the same car. I dont know about the new motor dyno numbers but the car runs alot better??????
Old Nov 18, 2004 | 04:13 PM
Default Re: LS whp? post your numbers people! (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">My new 2.0 nonvtec made 195/138 and went 12.12 @ 111. My old 2.0 nonvtec made 198/148 and went 12.48 @ 107 in the same car. I dont know about the new motor dyno numbers but the car runs alot better??????</TD></TR></TABLE>
405 cams compared to 404, what do you think?
What compression are you running?
Old Nov 18, 2004 | 07:42 PM
joboost13's Avatar
404's should b good 4 my setup, all that is getting done 2 the bottom is arp rod bolts, so when i tune it i can safly rev 2 about 7500rpm which i think is were 404's make peak hp wit the cr iam going 2 have. Dont know what 2 tune it wit though, was thinking of a SAF-CII, with some cam gears.
Old Nov 19, 2004 | 09:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joboost13 &raquo;</TD></TR><TR><TD CLASS="quote">404's should b good 4 my setup, all that is getting done 2 the bottom is arp rod bolts, so when i tune it i can safly rev 2 about 7500rpm which i think is were 404's make peak hp wit the cr iam going 2 have. Dont know what 2 tune it wit though, was thinking of a SAF-CII, with some cam gears.</TD></TR></TABLE>
Yeah, all I have done to the bottom end is arp rod bolts for some insurance on the top end where the b20 doesnt like to rev at. All I have for tunning for now is STR cam gears, B&M fpr, and a Apexi SAFC. Later down the road I plan on tunning it with uberdata but still have to look into that.
Joboost13, your set-up is near the same thing as the one im building. What bolt-ons you plan on running? Whats the b20 going into?
Old Nov 19, 2004 | 12:05 PM
joboost13's Avatar
its going into my 94 teg, 4 bolt ons i dont really know. I was going 2 finish my exhaust wit 2 1/2 piping 2 some jdm dc 4-1 headreds wit a 2.5 collecter 2 start. Then i was going 2 shave .30 of my spare head and get it pnp'd.
Old Nov 19, 2004 | 12:10 PM
-DC2-'s Avatar
130whp/120wlbft &lt;- click
Old Nov 19, 2004 | 12:20 PM
joboost13's Avatar
Default Re: (DOHCDX)
pretty good numbers
