anyone with a itr turbo?
i just finished installling drag gen III on my b18c5 EK. rite now im planning on boosting 5psi for daily driven. i have RC 370 injectors SX 1.1 regualtor holly fuel pump and a vafc.. anyone recommend anything else?? what about a low compression head gasket? rite now i dont have the time or funds to rebuild the bottomend..
my other car is a 98ex it once had this drag kit on it and i blew 3 piston ringlands on the b16a2 stock internal
once i built the whole bottom end.. the darton Sleaves sunk on me..
does anyone know if my b16a2 je pistons will fit my b18c5?? how about the crowder rods?
thanks
thanks
I have the HKS headgasket and it works fine. But if you plan on buildin your motor at some point, I would just keep the boost at 5 psi, tune conservatively and save up for internals, etc.
how good are they? inlinepro i heard makes great ones..
i know the best way is to pistons and rods ect.. ive been there done that.. but funds are shourt rite now.. inline pro?
how thick are they? I will be using a 2mm one supplied wit my kit...but my compession will still be be high...i am doing like cr 11:1 now, so it'll probablty take it down to 10's...plus I will be usin 96+ octane fuel.
but anyways, anything thicker than 2mm should be okay. HKS makes a good one and so does Top Fuel. I don't know about inlinepro...
If your not gonna build the motor then I would get the headgasket. I have an HKS and it works fine. I've also heard good things about the inline pro headgasket. I would also recommend a J&S if you are concerned about blowing the motor and want to tune agressively with a good amount of boost...
inline and J&S...humm, get ready to spend around 800 bucks right there....You could've had the bottom end redone again for alittle more than that....
acually i prob wont get teh J&S.. ill prob just go with the gasket for now.. i dont have time any more to tear apart my motor.. and my engine bay on the EK is freshly painted and when i did the swap i put it in soo nicely without any scratches im scared if i take it out and put it back in i might scratch the paint in the bay.
http://www.inlinepro.com
there head gaskets are great....for some reason those guys make cars faster than they should be
i've only been to the track once since i have had this set-up.i had the boost down some just trying to get used to driving it.it is having serious traction problems.just need to work out the bugs.
it's all custom.it started as a drag kit but the only thing left drag is the manifold and it's about to go.
damn...only 196XX miles on my teg and already new race engine
Jeff-
Why would you like to lower your cr with only 5psi of boost? I run 5.5psi with 11,1:1 cr more than 1 year now and I´m currently upgrading the boost to 8psi. This is daily driven.
