anyone with a itr turbo?
Old Dec 27, 2001 | 09:07 AM
GoQkRaCeR's Avatar
Default anyone with a itr turbo?
i just finished installling drag gen III on my b18c5 EK. rite now im planning on boosting 5psi for daily driven. i have RC 370 injectors SX 1.1 regualtor holly fuel pump and a vafc.. anyone recommend anything else?? what about a low compression head gasket? rite now i dont have the time or funds to rebuild the bottomend..
my other car is a 98ex it once had this drag kit on it and i blew 3 piston ringlands on the b16a2 stock internal
once i built the whole bottom end.. the darton Sleaves sunk on me..
does anyone know if my b16a2 je pistons will fit my b18c5?? how about the crowder rods?
thanks
Old Dec 27, 2001 | 10:29 AM
TurboTypeR98's Avatar
New User
Default Re: anyone with a itr turbo? (GoQkRaCeR)
I have the HKS headgasket and it works fine. But if you plan on buildin your motor at some point, I would just keep the boost at 5 psi, tune conservatively and save up for internals, etc.
Old Dec 27, 2001 | 01:06 PM
MiraiZ's Avatar
Default Re: anyone with a itr turbo? (TurboTypeR98)
low compression gasket is a must if you don't want to do bottom end work...
Old Dec 27, 2001 | 01:07 PM
GoQkRaCeR's Avatar
Default Re: anyone with a itr turbo? (MiraiZ)
how good are they? inlinepro i heard makes great ones..
i know the best way is to pistons and rods ect.. ive been there done that.. but funds are shourt rite now.. inline pro?
Old Dec 27, 2001 | 01:15 PM
MiraiZ's Avatar
how thick are they? I will be using a 2mm one supplied wit my kit...but my compession will still be be high...i am doing like cr 11:1 now, so it'll probablty take it down to 10's...plus I will be usin 96+ octane fuel.
but anyways, anything thicker than 2mm should be okay. HKS makes a good one and so does Top Fuel. I don't know about inlinepro...
Old Dec 27, 2001 | 01:17 PM
New User
If your not gonna build the motor then I would get the headgasket. I have an HKS and it works fine. I've also heard good things about the inline pro headgasket. I would also recommend a J&S if you are concerned about blowing the motor and want to tune agressively with a good amount of boost...
Old Dec 27, 2001 | 05:51 PM
turbotypeR@SPEC's Avatar
25 Year Member
buy an inlinepro headgasket.it will be worth it.
Old Dec 27, 2001 | 05:59 PM
GSteg's Avatar
Default Re: anyone with a itr turbo? (turbotypeR)
hey turbotypeR.. how you managed to get 434whp? thats crazy! but how come your times are kinda.........
Old Dec 27, 2001 | 06:59 PM
MiraiZ's Avatar
Default Re: anyone with a itr turbo? (GSteg)
he's probably on street tires...
Old Dec 27, 2001 | 09:59 PM
paulzy's Avatar
his trap speed should be up there though
Old Dec 27, 2001 | 10:38 PM
1fstevo's Avatar
New User
Look like this?
[Modified by [Evo]Hybrid, 7:39 AM 12/28/2001]
[Modified by [Evo]Hybrid, 7:40 AM 12/28/2001]
[Modified by [Evo]Hybrid, 8:17 AM 12/28/2001]
Old Dec 28, 2001 | 06:08 AM
GoQkRaCeR's Avatar
i think i will go with the Inline pro gasket.. hmm still thnking on the J&S rite now
Old Dec 28, 2001 | 12:34 PM
paulzy's Avatar
inline and J&S...humm, get ready to spend around 800 bucks right there....You could've had the bottom end redone again for alittle more than that....
Old Dec 28, 2001 | 01:20 PM
GoQkRaCeR's Avatar
Default Re: anyone with a itr turbo? (Slow_ass_4dr)
acually i prob wont get teh J&S.. ill prob just go with the gasket for now.. i dont have time any more to tear apart my motor.. and my engine bay on the EK is freshly painted and when i did the swap i put it in soo nicely without any scratches im scared if i take it out and put it back in i might scratch the paint in the bay.
Old Dec 28, 2001 | 02:02 PM
DR. ON POINT's Avatar
Banned
http://www.inlinepro.com
there head gaskets are great....for some reason those guys make cars faster than they should be
Old Dec 28, 2001 | 06:46 PM
25 Year Member
i've only been to the track once since i have had this set-up.i had the boost down some just trying to get used to driving it.it is having serious traction problems.just need to work out the bugs.
Old Dec 28, 2001 | 07:44 PM
GSteg's Avatar
what turbo kit do you have cuz thats amazing!! i'll live for 300whp..but 434!!
Old Dec 28, 2001 | 07:56 PM
25 Year Member
it's all custom.it started as a drag kit but the only thing left drag is the manifold and it's about to go.
Old Dec 28, 2001 | 08:52 PM
GSteg's Avatar
you're my new hero
Old Dec 29, 2001 | 06:40 AM
SpeedMonkeyRacing's Avatar
hehe..I have FMAX turbo and the only thing I ditch is the MF2 and 2 injector (and BTM)..everything else pretty much stays and I'm going to max out the t3/t4 efficiency (450whp) when the car is done (under the knife now)
damn...only 196XX miles on my teg and already new race engine
Jeff-
Old Dec 29, 2001 | 07:12 AM
Banned
u are gettin 434 hp out of a drag manifld....no boost spikes??? and ur only runing 12.5???? something sounds fishy
Old Dec 29, 2001 | 07:19 AM
MiraiZ's Avatar
Default Re: anyone with a itr turbo? (On Point EK)
What grade motor oil are you Turbo R guys using? Iwas thinking of going either 10w-50 or 5w -50...
Old Dec 29, 2001 | 07:20 AM
austrian type-R's Avatar
Why would you like to lower your cr with only 5psi of boost? I run 5.5psi with 11,1:1 cr more than 1 year now and I´m currently upgrading the boost to 8psi. This is daily driven.
Old Dec 29, 2001 | 08:50 AM
MiraiZ's Avatar
Default Re: anyone with a itr turbo? (austrian ITR)
better to be safe than sorry...
Old Dec 29, 2001 | 09:41 AM
TurboITR's Avatar
5w-30
