Fixing Timing Belt that has slipped a tooth.
Old Nov 16, 2004 | 06:37 PM
DrewDown's Avatar
Default Fixing Timing Belt that has slipped a tooth.
Last week my distributor seized and I am pretty sure my timing belt slipped a tooth. Car was running fine then it shut down and would not start. I replaced the distributor with one from Distributor King. The car starts and idles fun, but the distributor is turned as much as it will go and the timing is still a little off. The car bogs down low and is getting real bad gas mileage.
Now I was wondering what I have to go through to fix this. I changed the timing belt about 20,000 miles ago and am hoping it is not as complex as that. I was wondering if I could just take the valve cover off to get to the cam gears. If anyone could help me out I would appreciate it. I searched but could not find any info, just a few posts about other people who had a distributor problem cause their timing belt to slip. TIA.
Old Nov 16, 2004 | 07:36 PM
mmuller's Avatar
Mad Scientist
Default Re: Fixing Timing Belt that has slipped a tooth. (DrewDown)
just take your valve cpver off along with the side plastic cover and check timing
Old Nov 16, 2004 | 08:11 PM
DrewDown's Avatar
and what if the timing is off? I have to release the tension correct. Im sorry it has been a while and since I messed with the timing belt. Could I fix it with just the valve cover off?
Old Nov 17, 2004 | 05:32 AM
JimBlake's Avatar
Default Re: (DrewDown)
https://honda-tech.com/zero...05390
Old Nov 17, 2004 | 12:26 PM
DrewDown's Avatar
Thanks JimBlake
Old Nov 18, 2004 | 07:05 PM
DrewDown's Avatar
I took your advice Jim and it worked. I did not use a hanger however. I pulled the valve cover and put the motor at top dead center and sure enough the timing belt had slipped a tooth. I just loosened the tensioner bolt and slid the timing belt off the cam gears and lined everything up. Then I just slid the belt back on, tightened everything back up according to spec.
the car is running much better now. No more bogging or smelling like gas when I drive.
Also according to these posts and others like it, it was a common problem in 92-93 integras and Acura even had a recall on the distributors.
http://www.g2ic.com/forums/sho...ipped
http://www.g2ic.com/forums/sho...butor
Chev
Jul 23, 2018 10:56 AM
bnwbass
May 14, 2016 12:37 PM
zx92027xz
Aug 11, 2012 06:47 AM
suje
10
Feb 21, 2012 09:12 AM
handa
Jul 30, 2004 11:19 PM
