93 Civic HB rear brake conversion to 96 Integra GSR question?
Old Nov 16, 2004 | 05:57 PM
jefe's Avatar
Default 93 Civic HB rear brake conversion to 96 Integra GSR question?
Guy I am talking to is selling the parts. Rear trailing arms plus discs, calipers, etc.
If what I have researched is correct, the 96 GSR parts will just bolt on, correct?
And I have also read that in some cases, it is necessary to change prop valve and master cylinder but not necessary in others.
I didn't see anything specific to this application.
Does anyone know if this is necessary to have on initial install of the other parts? Or if it can wait for future upgrade, but still ok to drive now?
Also, if I need to upgrade these parts now, do I find these parts from the same year, model car?
Thanks for any help. And please no smart *** answers or bitching about this being a repeat post. I'm sick of it. It isn't a repeat to me.
Thanks again.
Old Nov 16, 2004 | 06:15 PM
A.E Motoring's Avatar
Default Re: 93 Civic HB rear brake conversion to 96 Integra GSR question? (jefe)
yes it will fit...i have the same set up on my coupe...and about the prop and cylinder u dont have to really...just make sure that u bleed the brakes right...after the swap u will feel that your pedal will go down the floor before it grabs thats where the bleeding comes in...u can also get the cylinder and the prop valve but isnt dont really need it..i didn't have to replace anything and it felt alot better than before the swap...but keep in mind that i did bleed all 4 brakes. good luck with the install
Old Nov 16, 2004 | 06:28 PM
Default Re: 93 Civic HB rear brake conversion to 96 Integra GSR question? (JDM BoI)
https://honda-tech.com/zerothread?id=820484
Mrtrunks
Jun 15, 2008 08:20 AM
spyderman_8_2
Jul 7, 2006 08:26 AM
knockout
Mar 31, 2005 01:23 AM
jefe
Nov 21, 2004 02:54 PM
Smashback
Mar 5, 2002 04:23 AM
