who makes good allmotor b18 cams?
Old Nov 16, 2004 | 05:09 PM
wpgcivic's Avatar
Default who makes good allmotor b18 cams?
like the title says who makes good all motor b18 cams? as of now i am leaning towards the exospeed race cams...thanks
Old Nov 16, 2004 | 05:27 PM
wpgcivic's Avatar
ttt
Old Nov 16, 2004 | 05:29 PM
evilempire's Avatar
do a search! if you don't tell us what your specs, goals, and uses of the engine are we can't help! help yourself first!
https://honda-tech.com/zerosearch
Old Nov 16, 2004 | 05:47 PM
wpgcivic's Avatar
ive searched many times but all i find is lsvtec and vtec cams
anyways
b18b bottom end and head
skunk IM
CTR pistons, ls rods
i want to make a fast all motor ls
therefore the most powerful teh best
Old Nov 16, 2004 | 06:50 PM
therealpoorboy's Avatar
Default Re: (wpgcivic)
edit. didnt relize you wanted non- vtec stuff.
Modified by therealpoorboy at 7:30 AM 11/17/2004
Old Nov 16, 2004 | 07:21 PM
wpgcivic's Avatar
ummm, a non-vtec revving to 10k? wow
Old Nov 16, 2004 | 07:51 PM
boosted k20's Avatar
NON VTEC LS B18A/B motors, the best cams is CROWER. Stage 2 will give 15-18 HP part # is 62403
Stage 3 will give over 20 hp. part number is 62404. for a serious full race car the have a stage 4 :62405
I would recommend the 403 or 404's (404s more preferably). im rocking the 403's but will probably switch to 404's after i build my bottom end and swap in a b16 tranny.
when u get these cams u will need to get CROWER valvsprings as well. also high compression pistons will make these cams shine!
http://www.crower.com
Old Nov 16, 2004 | 09:02 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: who makes good allmotor b18 cams? (wpgcivic)
Give Rocket Motorsports a call and see what they can do for you. Rocket will grind cams for all sorts of things.
Find contact info at: http://www.m24x.com
Old Nov 17, 2004 | 08:16 AM
wpgcivic's Avatar
how streetable are the crower 405's?
Old Nov 17, 2004 | 08:31 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
I have the Exospeed LS909's and i love them. I dont think theyre gonna be enough for you though. I would prolly go with 404's if i were you....you dont really have the CR to justify 405's. But thats just my opinion. I say you should get some rollerwaves and throw in some 405a's...sure itd be a bitch to drive on the street...but that thing would haul ***
Old Nov 17, 2004 | 08:37 AM
qcktegls's Avatar
Default Re: (sCeRaXn)
you have the compression to build for the 404's. 403's are for daily driving and if you have the right mods done then they can go pretty good. i say go with the 404's cause of the ctr pistons but the valve springs and retainers are a must so u can take the redline higher. i also suggest new rods because the stock rods dont take very kindly to 8000 rpm redline frequently.
Old Nov 17, 2004 | 08:40 AM
wpgcivic's Avatar
with my buddys lsvtec he took his stock ls rods all the way to 10000 all year long and for 2 seasons they are still good, with teh crt pistons the CR is high enough right? i really want to make good power so i was leaning towards the 405's as long as i use crower valve train and build a solid head
Old Nov 17, 2004 | 08:44 AM
qcktegls's Avatar
im puttin the 403's in my ls and many people on this site have told me to go with different rods just to be safe. it wont run you to much. you dont have to put in new rods but its just a suggestion.
Old Nov 17, 2004 | 09:07 AM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: (qcktegls)
I have heard nothing but really good things about the crowers on non-vtecs, as far as rods go w/ that setup you could prob get away w/ shotpeening yours but if you can stretch for a set of forged rods you'd be golden
Old Nov 17, 2004 | 09:18 AM
dfoxengr's Avatar
Default Re: (boosted k20)
crower, or cheap regrinds if you dont have much money
Old Nov 17, 2004 | 09:22 AM
Default Re: (hybridvteceg)
oh yeah I think StyleTeg ran the crowers, if I'm wrong correct me, but he's really knowledgable and def a nice guy he'd prob be willing to help you
Old Nov 17, 2004 | 10:03 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">how streetable are the crower 405's?</TD></TR></TABLE>
Not very streetable! I have 404's and high compression and my car isnt very streetable!
Are going all out or is this a daily driver?
Old Nov 17, 2004 | 04:26 PM
wpgcivic's Avatar
its a streetable/track car
Old Nov 17, 2004 | 07:37 PM
if it's see n street time them defintily stay away from the 405's. **** will be loping like a bitch and proably will be idling at 1500! highest i would go is the 404's. make sure u get the car tuned after the install. i had 403's in my car for about 2 months now and still untuned. gonna tune it after i install PR3 pistons. gas mileage sucks as hell right now untuned.
im not gonna shotpeen my rods. also wont be reving it past 7K. i should be able to get away without shotpeeing the rods right?
Old Nov 17, 2004 | 07:39 PM
wpgcivic's Avatar
now lemme ask this, is all motor b18 worth it?
Old Nov 17, 2004 | 07:58 PM
turbo is usaully faster and u get more HP for the money. but not alot of people build all motor LS's. be different from the rest of the VTEC dudes. it's even better when u spank a GSR or LS/VTEC with a built LS. with cams and pistons and other goodies and tuning, u can geta LS to run low 14's in an integra shell with interior. put the same LS in a hatch and it will be pulling 13's all day
Old Nov 17, 2004 | 08:10 PM
B18OnTop's Avatar
As itsallmotor said. This is a really good thread!!! https://honda-tech.com/zerothread?id=818820
B18b is great for all motor. You can get some fairly respectable power out of one.
-Aaron
boostfever
Sep 21, 2011 09:11 PM
chode2002
Mar 27, 2009 01:13 PM
integratypeRs
Nov 29, 2008 12:49 AM
DriveSideWays
Apr 28, 2004 03:24 PM
L5turbo415
Apr 1, 2004 03:59 PM
