broken knock sensor...
Old Nov 16, 2004 | 04:20 PM
DiSbaDbOi's Avatar
Default broken knock sensor...
i just broke my knock sensor today...and i was wondering how big of a difference is a knock sensor on and off your car...?? even tho i got a bone stock d16y8..
Old Nov 16, 2004 | 04:28 PM
DiSbaDbOi's Avatar
Default Re: broken knock sensor... (DiSbaDbOi)
bump...
Old Nov 16, 2004 | 04:49 PM
JDMlyfestyle's Avatar
If the code registers it could throw your car into limp mode.
Old Nov 16, 2004 | 04:50 PM
Built to Spill's Avatar
el diablo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">If the code registers it could throw your car into limp mode.</TD></TR></TABLE>
Im sure it will..its just a matter of time.
Your car will run terribly with a broken knock sensor.
Old Nov 16, 2004 | 05:22 PM
Your car will run like absolutely **** if you have a broken knock. or you could do a OBDII&gt;OBDI conversion
Old Nov 16, 2004 | 05:39 PM
DiSbaDbOi's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Your car will run like absolutely **** if you have a broken knock. or you could do a OBDII&gt;OBDI conversion</TD></TR></TABLE>
instead of doing all that cant i just replace the knock sensor?
Old Nov 16, 2004 | 05:41 PM
BauleyCivic's Avatar
Risky Business
Default Re: (DiSbaDbOi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DiSbaDbOi &raquo;</TD></TR><TR><TD CLASS="quote">
instead of doing all that cant i just replace the knock sensor?</TD></TR></TABLE>
Yep
Old Nov 16, 2004 | 05:44 PM
Ya you can just replace the sensor.... But OBDII computers are alot easier to trip codes on compared to OBDI computers
Old Nov 16, 2004 | 05:55 PM
DiSbaDbOi's Avatar
JDMlyfestyle...PMed!!
Old Nov 16, 2004 | 05:58 PM
right back at cha
Old Nov 16, 2004 | 06:43 PM
inane's Avatar
that would explain why my car runs like *** right now :D it likes to bog down a lot and then speed up... i won a knock sensor on ebay and im waiting for them to mail it now... hopefully that will get rid of my CEL and make the car run better
Old Nov 16, 2004 | 06:45 PM
Kamin's Avatar
Default Re: (inane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inane &raquo;</TD></TR><TR><TD CLASS="quote">that would explain why my car runs like *** right now :D it likes to bog down a lot and then speed up... i won a knock sensor on ebay and im waiting for them to mail it now... hopefully that will get rid of my CEL and make the car run better</TD></TR></TABLE>
uh
why not look at the CEL? it could be completley unlreated to the knock sensor.
it never ceases to amaze me people just throw parts at a problem without diagnosing it.
Old Nov 16, 2004 | 06:59 PM
inane's Avatar
Default Re: (Kamin)
er, i guess i worded what i said wrong... i did diagnose it and my CEL is for the knock sensor... what i meant was that i was hoping that when i replace the knock sensor, that it will make my CEL go away... because im annoyed with it and i want it gone right now...
Old Nov 18, 2004 | 08:40 PM
EK k kay's Avatar
Default Re: (inane)
Replacing the knock sensor may fix it unless it's not broken and the sensor is in fact hearing some sort of knocking in your block.
Old Nov 19, 2004 | 09:42 AM
klungemonger's Avatar
You can get used knock sensors, they still cost a bit but who knows how reliable they are...and new ones are well over $100. Why not use the cash to pick up a P28 ecu which doesn't look for a knock sensor? Another $74 for the OBD1 conversion harness and you're set.
Old Nov 19, 2004 | 02:36 PM
DiSbaDbOi's Avatar
Default Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">You can get used knock sensors, they still cost a bit but who knows how reliable they are...and new ones are well over $100. Why not use the cash to pick up a P28 ecu which doesn't look for a knock sensor? Another $74 for the OBD1 conversion harness and you're set.</TD></TR></TABLE>
so if i was to go OBD2-OBD1 i wouldnt need a knock sensor?
Old Nov 19, 2004 | 06:12 PM
inane's Avatar
i just got a used knock sensor from someone on ebay for like $50
the dealer wants like $150 for one... so it was a lot cheaper
Old Nov 19, 2004 | 07:41 PM
so if i was to go OBD2-OBD1 i wouldnt need a knock sensor?</TD></TR></TABLE>
As long as you use a P28 that is correct. Also if you have OBD1 you can think about ecu mods down the road.
luv2boost
Jul 5, 2007 09:43 PM
ELSUICIDA
Apr 15, 2007 05:13 PM
integg93
Aug 3, 2006 01:17 PM
ek9jdm
Jul 22, 2006 11:36 AM
Grnade
May 2, 2005 08:45 PM
