Is it possible to drop in Toda b's and get an OK idle without having a VAFC?
Old Dec 27, 2001 | 07:43 AM
blazin's Avatar
Default Is it possible to drop in Toda b's and get an OK idle without having a VAFC?
Can you get a decent idle out of Spec B's without any sort of aftermarket fuel controller like a VAFC or Fields?I don't have one at the moment.I do have a fuel press. reg though if that could help at all and adjustable cam gears.
Old Dec 27, 2001 | 07:54 AM
Black R's Avatar
25 Year Member
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (blazin)
No.
Old Dec 27, 2001 | 07:55 AM
travis's Avatar
You can dial out some of the overlap at idle with the cam gears. That will smooth things out a little. (*EDIT* that will obviously dial out overlap everywhere, leading to a loss in power, FYI).
It's also nice to have some fine fuel tuning, though, so I would address that ASAP if you're going to get the cams.
[Modified by ITR#231, 9:57 AM 12/27/2001]
Old Dec 27, 2001 | 08:50 AM
JoyrideII's Avatar
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (ITR#231)
Black R are you running stock or aftermarket valve springs and retainers...
Old Dec 27, 2001 | 08:56 AM
B18CXr's Avatar
if cam gears are at 0,0. idle will be almost stock.
Old Dec 27, 2001 | 09:05 AM
Johnny Tran's Avatar
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (B18CXr)
leave em lumpy
Old Dec 27, 2001 | 09:14 AM
AssPenny's Avatar
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (Blue-POS)
Looping rocks
Old Dec 27, 2001 | 09:53 AM
Mike M's Avatar
Founding Member
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (AssPenny)
BWAPBWAPBWAPBWAP
Old Dec 27, 2001 | 10:35 AM
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (TypeRmsm)
i like em lumpy...like your grandma's mashed potatos
Old Dec 27, 2001 | 11:35 AM
Black R's Avatar
25 Year Member
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (JoyrIdeII)
Pretty much toda everything... including valve springs.
I know that my car wouldn't idle without leaning it out ~25% and even if I did what yack suggested, why? Have a good (stock) idle would mean a loss of power for me... Been there, done that. Besides, you have to tune and will need a vafc for that.....
Old Dec 27, 2001 | 12:36 PM
mafay2's Avatar
New User
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (Black R)
My car can idle without any fuel controller with Spec B, but I did have Yoshio reprogrammed the ECU. With Spec B, you will need to get something to control the fuel in order to have it run good. For some reason, when I adjust the cam gear, the idle was not affected by too much. I even have setting like +5, -4, and it still idle almost the same as it is at 0,0.
Old Dec 27, 2001 | 02:43 PM
ITR764's Avatar
ha ha!!
Old Dec 27, 2001 | 02:50 PM
TODAwhore's Avatar
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (ITR764)
you have to run some kind of fuel controll vafc,ect.... unless you don't care about your car ildeing..mine at 0,0 settings need to run about -24@1000 to keep it running...also vafc or power fc will let you tune out more power
Old Dec 27, 2001 | 03:33 PM
VTEC4GS's Avatar
It is possible to get a lumpy idle without any stalling ... only a very few prolly know how to do this.
Greg
Old Dec 27, 2001 | 03:35 PM
Austin's Avatar
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (vtec4gs)
Greg
Alright, what's the secret? Mine doesn't die, and I have no idea what I did to make it that way...though I do have an idle around 950rpm
Old Dec 27, 2001 | 03:43 PM
mafay2's Avatar
New User
My spec B idle at around 800rpm, usually very stable, but sometime it go up and down from 650-950rpm. MY cam gear setting is at +4,+1 now. And I leaned out the idle by -6% with the VAFC. I think timing is set at 18 degree.
Old Dec 27, 2001 | 03:59 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (mafay2)
-6? Ha! I was at -38 @ 1000 before I went to my "winter" (pass emissions) tune...
Old Dec 27, 2001 | 04:29 PM
mafay2's Avatar
New User
Default Re: Is it possible to drop in Toda b's and get an OK idle without having a VAFC? (itr009)
Well, my car can idle even if I set 1000@ +3%, but since I want to save some gas when I have to warm up my car in the winter, I use the VAFC to lean it out a little bit. I don't know if I can lean out some more, but probably can.
Since the engine is running very lean in all other RPM range (+10 to +15%) else where, I would guess the idle wouldn't need to be lean out too much with the current ECU program.
Old Dec 27, 2001 | 04:41 PM
Splat's Avatar
...with the current ECU program.
Stock ECU or no?
Old Dec 27, 2001 | 08:06 PM
mafay2's Avatar
New User
Stock ECU or no?
No, I have a Yoshio chipped OBD2 ECU for the Spec B program!!
PY01ITR42
Feb 23, 2004 08:40 AM
PY01ITR42
Feb 22, 2004 05:31 PM
TypRice
Oct 2, 2003 04:50 PM
amrintegra
Dec 9, 2001 12:18 PM
ITR 0206
Jul 10, 2001 12:44 PM
