91 civic engine swap
Old Dec 27, 2001 | 07:31 AM
archie's Avatar
Default 91 civic engine swap
91 civic base model 1500cc with a 4speed trans I have a motor and trans from a 91 civic dx with a five speed what changes have to be done to put five speed in and is it worth it. Shifter ?? Will my clutch cable fit , my axles?? Thanks
Old Dec 27, 2001 | 08:36 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: 91 civic engine swap (archie)
Unbolt old motor/tranny, drop in the DX motor/tranny. Use your old STD engine wiring harness and axles/clutch cable/etc.
Also swap the ECU.
I just did this not long ago. I bought a STD HB 4 speed with blown motor for $60 and a wreck DX HB for $200.
Old Dec 27, 2001 | 12:40 PM
archie's Avatar
Default Re: 91 civic engine swap (Mista Bone)
I do not have the ecu from the dx , is it a must or can I use the one I have???
Old Dec 27, 2001 | 05:06 PM
Mista Bone's Avatar
D Tranny Guru
STD motor will run lean without the DX ECU. Should be able to get one for $25-40 easy.
[Modified by Mista Bone, 9:06 PM 12/27/2001]
vtec_powah
May 31, 2005 06:22 PM
new_to_hondas
May 18, 2003 05:41 PM
