idling problems. HELP!
Old Nov 16, 2004 | 01:55 PM
civic-lsi-vtec's Avatar
Default idling problems. HELP!
civic lsi vtec 1996 3 door hatchback. d15Z6
since ive had the head gasket replaced idle fluctuates between 1000 -200.
When i come to a stop idles low and sometime stalls. Stalling increases if a put my foot down. Things ive done are:
throttle body cleaned
sparkys changed
ecu reset
air intake screw adjusted
vacuum pipes checked
Sometimes the car feels really rough and other times ok whilst idling. Usually happens when engine is warm. No engine light..
is this technical or what
Old Nov 16, 2004 | 02:06 PM
A.E Motoring's Avatar
Default Re: idling problems. HELP! (civic-lsi-vtec)
adjust your idle?
Old Nov 17, 2004 | 12:10 PM
Default Re: idling problems. HELP! (JDM BoI)
how can the idle be adjusted if the iacv is electronic.
Old Nov 17, 2004 | 12:12 PM
=GAME='s Avatar
adjust it with the idle adjusting screw on the tb.
Old Nov 17, 2004 | 12:16 PM
Default Re: idling problems. HELP! ([G][A][M][E])
there is no idle adjusting screw on the tb. The screw on the tb is the idle air intake screw.
Old Nov 17, 2004 | 01:32 PM
Syner-G-Racing LLC's Avatar
exactly you unplug the IACV hold the rpms at 3000 untill the fan kicks on and slowly let of the accelerator until it idles, then you slowly adjust the "screw on your throttle body". once you have it idling around 550-600 turn off the car plug the IACV back up and restart the car....then you should be idling around 850-900. with a good idle set, get in your car and drive to the auto store and purchase a haynes manual or turn off your car and sit in front of your computer and order a helms manual.
Old Nov 18, 2004 | 02:29 AM
Default Re: idling problems. HELP! (Syner-G-Racing)
thanks ill try it out and see how it goes.
Old Nov 19, 2004 | 11:24 AM
I have done the idle reprogramming without any success. I have come across another problem which may be connected. When the car is cold hesitates to idle high and i can feel the car engine shaking. It seems as though it is misfiring. Do u know what is causing this? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">exactly you unplug the IACV hold the rpms at 3000 untill the fan kicks on and slowly let of the accelerator until it idles, then you slowly adjust the "screw on your throttle body". once you have it idling around 550-600 turn off the car plug the IACV back up and restart the car....then you should be idling around 850-900.</TD></TR></TABLE>
Old Nov 20, 2004 | 10:19 AM
the problem happend straight after the head gasket replacement so could it have anything to do with the valve clearance. Like do the valves have to be reset? What do you think!
Old Nov 20, 2004 | 10:22 AM
slambedcivic's Avatar
bleed the air out of the cooling system...
the idle air control valve will not function properly if there is ait bubbles in it....
Old Nov 20, 2004 | 10:24 AM
Default Re: idling problems. HELP! (slambedcivic)
I have let the air out by bubbling it until the fan kicks in. anything else?
Old Nov 20, 2004 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-lsi-vtec &raquo;</TD></TR><TR><TD CLASS="quote">I have let the air out by bubbling it until the fan kicks in. anything else? </TD></TR></TABLE>
where did you bleed it from? did you let the car get hot enough for the thermostat to open to get coolant back up the the intake mani?
Old Nov 20, 2004 | 11:22 AM
yep i let the thermostat open
Old Nov 20, 2004 | 03:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-lsi-vtec &raquo;</TD></TR><TR><TD CLASS="quote">there is no idle adjusting screw on the tb. The screw on the tb is the idle air intake screw. </TD></TR></TABLE>
if youre looking @ the throttle body, on the top left of it, theres a little indentation. scrape the silicon out of there and there is your idle screw...
Old Nov 21, 2004 | 01:09 PM
on my civic the idle is adjusted via the iacv. I have followed the instructions to reset my idle from actual honda guide and it still has not resolved the problem. Could the valves cause this to happen as there are valves for the air system. Also the ignition timing?
Old Dec 6, 2004 | 05:17 AM
Hi. Problem sorted at last. It was a vacuum pipe underneath the inlet manifold that had come of causing the idle speed to go up and down. Also the timing was reset because the vacuum affects timing. Tappets were not reset during headgasket. So they had to be reset. Hope this helps!
Old Dec 24, 2004 | 05:26 AM
Kooner450r's Avatar
Help I have the same idling issue up and down when engine gets warm ,, what vacuum pipe was that and where my car was in serious collision and may have came off ,,, Thx
Toanz
Jun 23, 2008 03:57 PM
NAmodified
Dec 5, 2007 04:04 PM
AlxSiR7
Feb 1, 2005 11:42 AM
