suspension question...
I am about to pick up a set of teins ha's from a ef just wondering if they will fit on my da i think they will but just checking thnx guys...
you might need to change ur rear lower control arms to 88 crx si's or 97-01 integra type r's. the rear shocks have a differnt style mounting than ur da
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mystery machine »</TD></TR><TR><TD CLASS="quote">I am about to pick up a set of teins ha's from a ef just wondering if they will fit on my da i think they will but just checking thnx guys...
I don't know what kind of rear LCAs the 2nd gen Teg uses but my best guess is that it's similar to the 3rd gen non-Type-R ones. I have the HA's on my DC2 non-R and I had to get Type-R rear LCAs.
I can tell you one thing, you will love them. Another advice, make sure you coat the top perch where you adjust the dampening with anti-rust coating or what not, because in time it will rust if moisture is present inside your car. I know mine did. Other than that, I give the HAs
</TD></TR></TABLE>I don't know what kind of rear LCAs the 2nd gen Teg uses but my best guess is that it's similar to the 3rd gen non-Type-R ones. I have the HA's on my DC2 non-R and I had to get Type-R rear LCAs.
If I can guesstimate correctly, approx~ 14000 miles.
Once you get yours on, try to put it on the highest dampening. Your car will feel like it's riding on rails...literally. But I also have a 22mm sway (the next suspension upgrade I would recommend to you) which reduces body roll and rear upper strut.
ya i want to do that later along with spoon bars i hav a 4pt cage with cross bar and rear lower tie bar and shitty skunks 2 with tokico blues, ya the guy with the ha's has 15- 20 k on his and has has them 4 2 years i really wanna pick they up thnx 4 all ur help man what should i put on the damping thing as far as stoping rust pervention.
Go to an auto store and ask them for some antirust-sieze type of spray or coating. Tell them what you're going to use it for.
And how much are you getting yours BTW?
Coz I got mine $930 brand new out the door
OnceIwasMuffin
Jun 20, 2018 06:33 AM
