facelift crx with b18c , does ur hood closed properly ?
Old Nov 16, 2004 | 01:01 PM
Cyber ITR's Avatar
Default facelift crx with b18c , does ur hood closed properly ?
as the topic says , mine doesnt ....... the driver side < since ur guys in states .. > has quite a lot of gap !!!!! is my hood bent or what ??
Old Nov 16, 2004 | 01:15 PM
misfithamster's Avatar
Default Re: facelift crx with b18c , does ur hood closed properly ? (I See Dead People)
not sure about similar measurments but with my b20vtec in the ef i gut rubbing on the drivers side and it makes a gap as well.. a little skeletol shaving should fix it up im sure. im just too lazy
Old Nov 16, 2004 | 02:22 PM
rgaray's Avatar
If you get the ZC or Sir hood you will have no problems.
Old Nov 16, 2004 | 02:25 PM
Cyber ITR's Avatar
Default Re: (rgaray)
my car is a JDM EF8 , crx SiR
but **** me , the gap is HUGEEEEEEEEEEEEEEE
Old Nov 16, 2004 | 02:32 PM
Rywire's Avatar
Default Re: (I See Dead People)
I had to cut mine for it to fit perfect, but if you have a sir, it shouldnt be hitting. You have factory mounts, right?
Ryan
Old Nov 16, 2004 | 02:43 PM
Cyber ITR's Avatar
Default Re: (droppedcrxsi)
yes everything factory , its about 2in gap !!!!
i take a peek thru the gap , there was nothing there to stop the hood from closing properly !!!! the hood didnt even touch the engine !!
so what is it ?!?!
Old Nov 16, 2004 | 02:51 PM
APEX CRX's Avatar
Is this a new car to you? because it should not have a 2 inch gap. It might of been hit by another car while parked?
Old Nov 16, 2004 | 03:47 PM
turbo_ef9's Avatar
Default Re: (APEX CRX)
mine just rubs.. it doesn't push the hood up or anything..
Old Nov 16, 2004 | 04:48 PM
skittyscott's Avatar
Default Re: (eli_vang)
make sure you didnt leave a wrench on your shock tower or something...
Old Nov 16, 2004 | 04:54 PM
Stefndogg's Avatar
Default Re: (skittyscott)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skittyscott &raquo;</TD></TR><TR><TD CLASS="quote">make sure you didnt leave a wrench on your shock tower or something...</TD></TR></TABLE>
lol
Old Nov 18, 2004 | 02:47 AM
Cyber ITR's Avatar
Default Re: (Stefndogg)
no i have double , triple check , theres nothing under the hood !!!!!!!!!!!
grrrrrrr !@#)!_@#)_!@(_!@
Old Nov 18, 2004 | 03:52 AM
elmalouno's Avatar
i have a a b18c1 in my crx using hasport mounts. the hood rubs on the motor slightly on the driverside.
Old Nov 18, 2004 | 06:29 AM
Mr_CRX's Avatar
I know a lot of times the hoods get bent from being propped on that crappy stock prop for long periods of time, or if it gets pulled down whiel still propped, etc. Mine has about a 1/4" gap on the driver's side. But dang, 2" sounds like your car was in an accident...
Old Nov 18, 2004 | 02:30 PM
Cyber ITR's Avatar
Default Re: (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote"> I know a lot of times the hoods get bent from being propped on that crappy stock prop for long periods of time, or if it gets pulled down whiel still propped, etc. Mine has about a 1/4" gap on the driver's side. But dang, 2" sounds like your car was in an accident...</TD></TR></TABLE>
oh man !!!!! cuz my car has been propped for days when mechanic couldnt figure out the electrical problems that happened to my crx !
Old Nov 18, 2004 | 02:47 PM
Lil Red CRXsi's Avatar
Look closer at the hood-see if the is a bend in it somewhere.You won't get a 2" gap by just leaving the hood up for days,lol.Hate to say it but if it wasn't bad before,it must have been something that happened while it was at the shop.Maybe he was frustrated and leaned on the open hood beeing propped up by accident,don't know.
Old Nov 19, 2004 | 01:07 AM
Cyber ITR's Avatar
Default Re: (Lil Red CRXsi)
lol , ok so i went a panel beater today , and guess what they told me the hood has been damaged , i was like WTFFFFFFFFFFFFFFF
cuz when i bought the car , the hood closed properly , and now dayumm from the side u can slide ur fingers in !!!!!
Old Nov 19, 2004 | 02:19 AM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I See Dead People &raquo;</TD></TR><TR><TD CLASS="quote">as the topic says , mine doesnt ....... the driver side &lt; since ur guys in states .. &gt; has quite a lot of gap !!!!! is my hood bent or what ?? </TD></TR></TABLE>
you might have the wrong mounts for your ride. B16A is what your car was originally equiped with. the B18C engine is taller therefore will cause the problem you are in. some people (in the states) buy B16a mount kits thinking it will work for a B18C, and it will. but the hood will not close. the B16A mount kits used for the B18C are a good idea for those who wish to avoid scraping thier motors when going over uneven surfaces, but an after market hood or modified one is required. what mounts are you using? if using the mounts the B18C mounts try your stock B16A mounts. if you are using the stock B16A mounts try using the B18C mounts. hope this helps!
Old Nov 19, 2004 | 09:50 AM
Cyber ITR's Avatar
Default Re: facelift crx with b18c , does ur hood closed properly ? (Huggy Bear)
im using my b16a mounts sir
oh well i twisted the hood to the opposite site , and lol it looks way better now
u guys reckon if i use hood pins , the hood will closed properly ?
Old Nov 19, 2004 | 10:08 AM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I See Dead People &raquo;</TD></TR><TR><TD CLASS="quote">im using my b16a mounts sir </TD></TR></TABLE>
i suggest for proper fitment you use the B18C mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I See Dead People &raquo;</TD></TR><TR><TD CLASS="quote"> oh well i twisted the hood to the opposite site , and lol it looks way better now </TD></TR></TABLE>
sounds ghetto, oh well its your car do as you wish. i myself would not be able to sleep until it's done the right way. sounds as if you may be desperate.
tylojake
Dec 23, 2008 11:46 PM
Soichiro Jr.
Mar 26, 2008 01:53 PM
user 98292739
Nov 20, 2006 06:39 PM
VegaS10
Apr 4, 2006 10:23 AM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
