cel light codes how do i find them on a 1992 honda prelude si
look on ebay for the camber kits
check engine light codes .. there is a blue connector behind your radio .. you have to pull your radio/dash area out to get to.. stick a bent paper clip in the 2 sockets.. and it will start blinking.. (with key to acc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida »</TD></TR><TR><TD CLASS="quote">check engine light codes .. there is a blue connector behind your radio .. you have to pull your radio/dash area out to get to.. stick a bent paper clip in the 2 sockets.. and it will start blinking.. (with key to acc)</TD></TR></TABLE>
hmm, you don't mean pull the radio out do you?
Just reach around behind the center console - under the rear edge of the radio will be two connectors. It is the blue one, yes, but use a piece of wire if you can find one. Then as he says, turn the key to ACC and your CEL will blink the code.
Ricky Equihua
Nov 2, 2013 09:00 AM
