motor bogs under any throttle??
Old Nov 16, 2004 | 08:57 AM
zensoku207's Avatar
Default motor bogs under any throttle??
we have an ls/vtec swap installed and when the throttle body is opened at all, the motor bogs and almost stalls out, it won't rev at all. does it matter if the TPS plug faces up or down? its up tight now towards the drivers side.
thanks
Old Nov 16, 2004 | 12:00 PM
98itr0448's Avatar
Default Re: motor bogs under any throttle?? (zensoku207)
you need to check your tps voltage. It should be .45-.47 at idle, 4.45 at WOT. Check all your plugs and make sure everything is connected properly. Good Luck
Old Nov 16, 2004 | 02:13 PM
DefiantGSR's Avatar
Default Re: motor bogs under any throttle?? (LSVtecITR)
.45 idle, 4.5 WOT
Old Nov 28, 2004 | 05:39 PM
zensoku207's Avatar
i don't have a voltometer, so how if you guys had to look at it and guess how far in between the moutning screw is for it, what would you say?
Old Mar 21, 2005 | 10:50 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">we have an ls/vtec swap installed and when the throttle body is opened at all, the motor bogs and almost stalls out, it won't rev at all. does it matter if the TPS plug faces up or down? its up tight now towards the drivers side.
thanks</TD></TR></TABLE>leave this country now. scammers
WARNING DO NOT BUY FROM HIM
libral00
Jun 16, 2007 04:19 PM
GetawayInMoscow
Nov 21, 2006 07:57 AM
Scud
Aug 9, 2006 09:58 PM
slowhatch69
Jan 19, 2004 06:06 AM
Bictorious
Nov 2, 2003 09:46 PM
