B16B BHP=185 - Is this true with any VTEC head?
Old Nov 16, 2004 | 08:52 AM
7rrivera7's Avatar
Default B16B BHP=185 - Is this true with any VTEC head?
I have the opportunity to buy a B16B (CTR) short block. The 'net says this is a 185hp engine. My question is if this is true no matter what head I slap on or does it have to be a type r head.
I have a B16 head with a P&P from Alaniz and a flow chart stating if outperforms a virgen Type r head. If I use this will I get 185 horses?
Thanks!
Old Nov 16, 2004 | 09:15 AM
mmuller's Avatar
Mad Scientist
Default Re: B16B BHP=185 - Is this true with any VTEC head? (7rrivera7)
b16b= rev monster.
it already has an arrrrr head.
its basically a b16 (stroke wise) but with a b18 higher deck block; making of a great RS ratio
Old Nov 16, 2004 | 10:42 AM
TrnsferErr's Avatar
if your head is b16 head that you are gonna put on should outperform a type r head then yeah you should have around 185 hp, or more?? b16b is high compression. it depends on the cams u have too though. b16b is ctr cams.
Old Nov 16, 2004 | 10:50 AM
7rrivera7's Avatar
Default Re: B16B BHP=185 - Is this true with any VTEC head? (TrnsferErr)
That's what I though - higher compression but MMULLER above says the deck is taller. So are the rods longer?
MMULER, can you elaborate or point me to a web site that give more info? Thanks!
Old Nov 16, 2004 | 10:57 AM
mmuller's Avatar
Mad Scientist
yeah, rods are longer on the b16b and also pct pistons have a different compresson height than the rest; 1.210" for pct compared to like lets say pr3's 1.180".
Old Nov 17, 2004 | 03:41 AM
7rrivera7's Avatar
Default Re: B16B BHP=185 - Is this true with any VTEC head? (mmuller)
If I'm running a B16a, is a B16b a good upgrade?
Old Nov 17, 2004 | 04:55 AM
maxspeedhonda's Avatar
depends on your goals for the car, you could easily make your b16a faster for cheaper than the b16b
Old Nov 17, 2004 | 06:34 AM
AccordDX89's Avatar
Default Re: B16B BHP=185 - Is this true with any VTEC head? (maxspeedhonda)
A B16B is a destroked Type R. The block is an ITR block, just has the shorter stroke and a little less compression. 10.8 vs. 11. Put your P&P'ed head on and use CTR cams and you'll be above 185.
Old Nov 17, 2004 | 07:52 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: B16B BHP=185 - Is this true with any VTEC head? (AccordDX89)
YES the head makes a difference.. combustion chambers are shaped differently as well as the valves and etc...
Old Nov 17, 2004 | 03:22 PM
bossman032's Avatar
Default Re: B16B BHP=185 - Is this true with any VTEC head? (JDM_Ej)
b16b are good motors. I had a b16a second gen before. This motor loves to be revved. I sold my b16a and got this motor for about same cost. If you have a chance to get the B16b complete motor head,block,tranny your going to have some serious fun. then later on drop the gsr crank, rods, ctr pistons, maybe get some head work and tunning and cams your set....
b16b are not cheap if you find a good deal hop on it you won't be dissapointed if the motor is in healthy condition
slob20ef
13
Dec 2, 2009 11:18 AM
nix94delsol
Jul 29, 2007 06:52 PM
EG_Type R
Jun 25, 2004 03:23 PM
KB96VTEC
Dec 25, 2003 07:00 PM
-KangaRod-
25
Oct 11, 2003 07:41 AM
