Oil Filter Relocation Kit
Old Nov 16, 2004 | 08:44 AM
sorrule's Avatar
Default Oil Filter Relocation Kit
Hi all, forgive me if this is a dumb question but what is the significance of ab oil filter relocation kit? One other question, how do you know what size throttle body to use? Thanks
Old Nov 16, 2004 | 08:46 AM
Mike_C's Avatar
what size throttle body? depends on the application.
oil filter relocation kit? makes oil changes easier.
Old Nov 16, 2004 | 08:47 AM
brcivic411's Avatar
Default Re: Oil Filter Relocation Kit (sorrule)
an oil reolcation kit is usually used to make oil changes easier (placing the filter someplace more accessible) and can also increase the oil capacity of the engine if you user a larger filter.
The size of your intake manifold will most likely determine the size of your throttle body.
Old Nov 16, 2004 | 09:32 AM
monicle's Avatar
most oil filter relodcation kits have additional ports which can make the installation of an oil feed line, or oil temp/pressure gauge installs easier.
Old Nov 16, 2004 | 10:50 AM
endlesswinterco's Avatar
Default Re: Oil Filter Relocation Kit (monicle)
and the use of an oil cooler
Old Nov 16, 2004 | 01:14 PM
93CivicSI's Avatar
Default Re: Oil Filter Relocation Kit (brcivic411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 &raquo;</TD></TR><TR><TD CLASS="quote">an oil reolcation kit is usually used to make oil changes easier (placing the filter someplace more accessible) and can also increase the oil capacity of the engine if you user a larger filter.
The size of your intake manifold will most likely determine the size of your throttle body.</TD></TR></TABLE>
Old Nov 20, 2004 | 08:50 AM
al@n
Guest
Posts: n/a
Default Re: Oil Filter Relocation Kit (93CivicSI)
does anybody know where to get one of these relocation kits? i just spent an hour trying to get the filter off with only an inch of clearence between my face and the oil pan
bigsnorlax
Nov 6, 2009 06:43 AM
dclub01
May 1, 2003 03:22 PM
sslude
Feb 6, 2003 09:47 PM
travis
Nov 11, 2001 03:00 PM
travis
Nov 9, 2001 11:11 AM
