will gsr water pump, timing belt, valve cover gasket fit?
Old Nov 16, 2004 | 06:27 AM
rafiq7's Avatar
Default will gsr water pump, timing belt, valve cover gasket fit?
i have a ls block, b16 head,
taking it in for waterpump change,
i have heard that it can be replaced with gsr parts?
true?
Old Nov 16, 2004 | 06:52 AM
mr.beeks's Avatar
Default Re: will gsr water pump, timing belt, valve cover gasket fit? (rafiq7)
if you get the gsr pump also get the gsr timming belt
or you are going to find yourself in a short situation.
Old Apr 15, 2005 | 03:44 PM
Fuster_Cluck's Avatar
Default Re: will gsr water pump, timing belt, valve cover gasket fit? (mr.beeks)
GSR water pump a little larger than an LS?
Would like more info, thanks!
JTTeG_X
Jul 17, 2013 10:50 AM
b20steveo
May 3, 2009 08:51 PM
shortyz21
Nov 12, 2006 08:38 AM
11secEk
Feb 7, 2005 03:01 PM
TRE_
Apr 21, 2004 03:57 PM
