Aftermarket Thermostat question
Old Nov 16, 2004 | 04:45 AM
goldskiguy's Avatar
Default Aftermarket Thermostat question
I know that the OEM thermostat is designed to fail in the open position. If I replace it with one from a part store (Pep boys, Autozone, Trak auto, etc...) Will it also fail in the open position? This is a great engine-protecting feature and want to keep it with the new thermo.
Kris
Old Nov 16, 2004 | 05:23 AM
quiksheit's Avatar
Default Re: Aftermarket Thermostat question (goldskiguy)
When people say failing it means that the spring that it is made out of will wear out, leaving it in the open position. all thermostats should do this. When you go out and buy one you'll see what i mean. Oh and BTW they're about 12 bux.
HTH
Old Nov 16, 2004 | 06:45 AM
burnout289's Avatar
Default Re: Aftermarket Thermostat question (quiksheit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiksheit &raquo;</TD></TR><TR><TD CLASS="quote">When people say failing it means that the spring that it is made out of will wear out, leaving it in the open position. all thermostats should do this.</TD></TR></TABLE>
wrong. not all thermostats fail open. I know this first hand from multiple cars, including my integra. possibly later models than mine have the type you are talking about, but basically there are two kinds. I haven't shopped for one in a while, so I can't recall if it says on the packaging, but just ask someone in the shop. I'd call your local Honda dealer and ask if their OEM 'stats for your year are what you are looking for.
b16a27
Jun 21, 2007 11:48 AM
ACrite3404
Aug 28, 2006 09:34 PM
nek9
Jun 13, 2006 11:08 AM
David S. Wallens
63
Feb 13, 2005 04:29 PM
