Is the backlash on the steering rack adjustable?
... after replacing the end bushings I felt the backlash was a bit too big it makes noise during turning. BTW is a manual steering rack on a 95 hatchback.
Thanks for replying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K I T T »</TD></TR><TR><TD CLASS="quote">... after replacing the end bushings I felt the backlash was a bit too big it makes noise during turning. BTW is a manual steering rack on a 95 hatchback.
no, you cannot fix backlash on gears. the rack n pinion are simply worn
</TD></TR></TABLE>no, you cannot fix backlash on gears. the rack n pinion are simply worn
TeamNextGenChris
Nov 3, 2007 03:11 AM
JDM SLICK
Suspension & Brakes
17
Feb 14, 2006 10:20 AM
mtber
Dec 4, 2003 05:05 AM
