my car DIED on the way to work today
As i was pulling into my work parking lot, my car stalled. as i was still rolling i tried to start again and it turned over like no compression. i thought 'oh great, the timing belt...' i had just engough momentum to roll into a spot. i tried cranking again and for a second it had compression and fired and sputtered out and died. I tried it again and now it turns over like no compression all the time. what the hell could THAT be?
its a bone stock 90 dx
...took off the timing cover on break and saw my timing belt all loose and the cam timing out of whack. i lined everything back up at TDC and put the belt back on and i cant get my belt tensioner to tighten. is there a trick to getting the tensioner to tighten?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex »</TD></TR><TR><TD CLASS="quote">put pressure on the cal gear like your trying to turn it clockwise the tighten the tensioner</TD></TR></TABLE>
cal gear? did you mean cam gear or crank. rotate the cam gear clockwise so its tight on the frontside and tighten the 14mm bolt?
Crank pulley, if you have a socket turn it three times and it will tighten up, I.E. three complete revolutions of the pulley, if the tensioner is working properly.
I was just gonna ask you if you were sure the timing belt still had the teeth on it right before I scrolled down and saw your pic. Same thing happened to me in my Teg and it survived.
Project_ED8
Mar 5, 2004 12:32 PM
