Spark Plug gap for a "Poor man's type R" setup?
Old Nov 16, 2004 | 12:21 AM
90TT's Avatar
B A N N E D
Default Spark Plug gap for a "Poor man's type R" setup?
Sup Everyone, i am trying to find out what to gap my spark plugs to.
the spark plugs i am using are NGK BKR6E-11. i have a poor man's type r swap (B18c1 gsr block with a b16 SI head). i have searched and found some stating .044 to .051 gap.
thanks in adance!
Old Nov 16, 2004 | 07:24 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Spark Plug gap for a "Poor man's type R" setup? (90TT)
Just go out and get plugs for an ITR.
Old Nov 16, 2004 | 07:46 PM
90TT's Avatar
B A N N E D
Default Re: Spark Plug gap for a "Poor man's type R" setup? (JDM_Ej)
i already have the plugs that i am going to use! i am asking what i should set the gap to with the BKR6E-11
Old Nov 17, 2004 | 01:13 AM
Kataku2K3's Avatar
Just leave them at 44thou.
Old Nov 17, 2004 | 02:10 AM
gatesrex91's Avatar
Default Re: Spark Plug gap for a "Poor man's type R" setup? (Kataku2K3)
i thought with the new bosch 4 prong gapless plugs, we didnt have to worry about this stuff anymore...
Old Nov 17, 2004 | 02:40 AM
90TT's Avatar
B A N N E D
Default Re: Spark Plug gap for a "Poor man's type R" setup? (gatesrex91)
thanks Kataku2k3.
and gatesrex91, i only use NGK plugs
Old Nov 17, 2004 | 11:46 AM
Kataku2K3's Avatar
NGK
Old Nov 24, 2004 | 06:11 PM
spdweb.net's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gatesrex91 &raquo;</TD></TR><TR><TD CLASS="quote">i thought with the new bosch 4 prong gapless plugs, we didnt have to worry about this stuff anymore...</TD></TR></TABLE>
LOL @ bosch 4 prong gapless plugs.. Yeah those are worth your money! Ugh
Old Nov 24, 2004 | 08:37 PM
Jim Truett's Avatar
You don't really use those, do you?
Old Nov 25, 2004 | 01:14 AM
spdweb.net's Avatar
Default Re: Spark Plug gap for a "Poor man's type R" setup? (Jim Truett)
Yeah.. for anyone that cant take the hint.. Go NGK.. or whatever came stock in the car. Yeah Yeah I have heard all the arguments on this subject. Just think, your messing with the combustion chamber when you mess with plugs.. Don't ya think its better to use what the engine was designed and tested with?
As for the gap question.. Run the gap as wide as you can for your setup.. But NOT wider then recommended by the car manufacturer. If your running higher compression, whether its by engine mechanics, Turbo, Supercharger or you have a NOS setup you may need to close the gap a bit. Start with a little below stock and see how it runs at high RPM.. if there is no miss leave it. Your not going to gain performance by adjusting the gap if the engine is running fine. If it runs good leave it.
Also think about the heat range of the plug your using. A common misconception about gap is that it will change the heat of the plug. This is not the case. If your pinging, use a lower heat range plug... don't close the gap.
Old Nov 25, 2004 | 08:45 AM
asubennett's Avatar
Default Re: Spark Plug gap for a "Poor man's type R" setup? (spdweb.net)
I like .039 on an all motor car. If you are using a hot ignition like MSD you could open it back up to .045 or more if you choose.
civic_driver
11
May 29, 2009 06:00 PM
Lovemy99Lude
Jan 31, 2009 09:25 PM
1sikhatch
Feb 25, 2007 02:51 PM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
