what would cause an ignition coil to fry?
Old Dec 27, 2001 | 01:18 AM
dlric's Avatar
Default what would cause an ignition coil to fry?
my car died so i opened up the distributor and the ignition coil was fried. plastic was actually melted on the coil. any ideas what would cause this to happen?
thanks
Old Dec 27, 2001 | 05:37 AM
artifex's Avatar
say it
Default Re: what would cause an ignition coil to fry? (dlric)
i put some bosch platinum plugs in the crx i had a few years ago and i fried two ignition coils before i figured it out. are you using the right plugs?
Old Dec 27, 2001 | 06:04 AM
Spade's Avatar
Plugs that are too hot in igniting temp.
Old Dec 27, 2001 | 11:37 AM
dlric's Avatar
Default Re: what would cause an ignition coil to fry? (Spade)
that would make sense. i was running rich for a while (89 teg ecu runnin my higher compression d16z6)..i wonder if that could have had somethint to do with it..as the plugs were getting fouled up. well i replaced the coil and ignitor..i'll see if that does it. thanks
fastlimegreencivic
Classic Hondas
May 5, 2010 05:30 PM
julquimi
Nov 17, 2007 08:30 AM
1baddcivicsi
Oct 6, 2006 07:35 PM
^jefs0ng
Oct 28, 2003 02:53 PM
