headlights turning off or dimming then goes back on?
okay I have been having a wierd problem with my headlights on my 89 civic sedan occasionally dimming or turning off for a second then going back on full... any one else had this sort of problem?
I did put in some projector headlights I got on ebay but I had them in for at least 4 months before I first had problems.... so I don't know if it is a wiring thing or not...
Thanks! -Aaron
Thanks! -Aaron
well the headlights came with adaptors so I just pluged in the OEM connectors to them... maybe it could be a loose connection inside those though.... I just didn't know if there was some kind of relay I could check but I dont' think one exists for the headlights.... oh but when they dim they BOTH go at the same time... not just one
my advice
get a multimeter and start testing the line from the headlights to the fusebox... check fuse too, who knows maybe its on the way out.
ya I have checked fuses and I have one fuse for each side.... any ideas why BOTH sides would dim or turn off like that at the same time?
check voltage while driving , I had the same problem , no real method to the madness.
my entire cars lighting system was suffering from an alternator with a bum voltage regulator , I ran around for days with a mulitmeter and it finally happened , turns out I was getting over 15 volts on the tester when the problem would take place.
just a thought.
just a thought.
interesting... I have a recently replaced alternator ( less than 1 year) but occasionally I get up to 15 someting volt peaks just randomly. I wonder how that makes the lights dimmer... I would have though it would increase the intensity... and wattage... hmm
Thanks!
Thanks!
okay I have increased my theory a bit... more times than not, at the moment my headlights turn off it is when I flick the left blinker, but not often... and my foglights stay on all the time too... it couldn't be voltage spikes... when I get the chance I want to take apart my steering column and check connections...
