Need info on a H22 swap into my '95 civic
Old Nov 15, 2004 | 09:36 PM
Manofsnow's Avatar
Default Need info on a H22 swap into my '95 civic
I'm rather new at this whole hardcore car stuff so bare with me if I say something stupid.
I have a '95 Civic EX Coupe that I think need a wee bit more power. I have some friends that say the H22 is the best way to go as it is there favorite out of all their B series they have had in the past. I have been reading through and agree that the added torque gained is well worth the larger size from the B series. Also the cost seems to be a bit less...not counting mounts.
What I am asking for is some possible info to get me going. I have looked on hmotorsonline.com at engines, as well as searched through this site for info. Where can I find detailed info on what mounts needed, what all I need, and what it will run me in the full long run. So any info you can supply on where to find reliable engines for decent prices, swap walk-throughs?, and any other info would be great!
I do have quite a bit experiance with cars, I have ripped them apart, put them back together, replaced everything you can think of, just never done a swap quite like this one... thanx.
Old Nov 15, 2004 | 09:45 PM
mitsuman's Avatar
Default Re: Need info on a H22 swap into my '95 civic (Manofsnow)
top right hand corner youl see a search button. click that and do a search. check the archives. youl find some good info on h22 swaps.
Old Nov 15, 2004 | 09:53 PM
E dwinbon G's Avatar
Default Re: Need info on a H22 swap into my '95 civic (mitsuman)
https://honda-tech.com/zerothread?id=878010
Old Nov 15, 2004 | 09:57 PM
Manofsnow's Avatar
Default Re: Need info on a H22 swap into my '95 civic (E dwinbon G)
Yes, I have indeed read the https://honda-tech.com/zerothread?id=878010 and done the searches...maybe this will help:
This is what I am looking at getting:
http://www.hmotorsonline.com/s...30016
What tranny do I want? USDM, JDM, and what is the LSD Tranny?
Do I need the optional Hasboro kit?
Is there anything else that isn't show there that I need? I think this is what I was trying to say...thanx again! You guys are fast!
Old Nov 15, 2004 | 11:47 PM
94_HATCH's Avatar
This page has all the info you will ever need
https://honda-tech.com/zerothread?id=650329
Mounts are the easy part of the swap. There are basically two different kinds that most (not everyone) people use. Hasport and HCP. I have a 94 civic hatch with an h22a4. I used the HCP mounts because i got a good deal on them and talked to people that actually have them in their cars. Depending on where you buy the hcp mounts are about 200 bux less than the hasport mounts and every bit as good.
Wiring is very straight forward.
I would go with the jdm h22a instead of the usdm only because of the .5 higher compression. gives you an extra 10hp and 5 lbs/tq. Not much but every bit helps.
hope i answered what you were asking. If not just pm me and ill be glad to help
Old Nov 16, 2004 | 02:26 AM
Turbogixxer's Avatar
Default Re: Need info on a H22 swap into my '95 civic (94_HATCH)
Good job 94_HATCH
I was going to answer questions, but you beat me too it.
Old Nov 16, 2004 | 05:49 PM
94_HATCH's Avatar
Default Re: Need info on a H22 swap into my '95 civic (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Good job 94_HATCH
I was going to answer questions, but you beat me too it. </TD></TR></TABLE>
Thanks to you guys Ill be posting my writeup soon of my h22 swap into my eg hatch so be on the lookout. Got plenty of pics too
Old Nov 16, 2004 | 05:53 PM
Manofsnow's Avatar
Might sound stupid, but what is an "EG" civic?
Old Nov 16, 2004 | 05:54 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manofsnow &raquo;</TD></TR><TR><TD CLASS="quote">Might sound stupid, but what is an "EG" civic?</TD></TR></TABLE>
1992-1995 Civic
1996-2000 Is Commonly Referred to as "EK"
HaTeMyHoNdA
Jul 7, 2007 02:04 PM
Adams5
Feb 4, 2004 05:15 AM
newb23
Sep 8, 2003 04:29 PM
