where is the pcv valve?
Old Dec 27, 2001 | 12:18 AM
Volcom's Avatar
Default where is the pcv valve?
i looked in the helms manual and I couldn't find out where exactly it was. Any help? If I change the valve out, will i get back some of the lost mpg that I have seen lately?
Thanks
Old Dec 27, 2001 | 04:28 AM
9KRacer's Avatar
New User
Default Re: where is the pcv valve? (Alphanumeric)
Its on the intake manifold.
Old Dec 27, 2001 | 06:29 AM
BSQ's Avatar
BSQ
You didn't mention which year and model Integra you have, but if you have a '94-'01 GS-R the PCV valve will be located on the backside of the engine block on top of the oil breather chamber. Here is a diagram from the Helms manual which show where it is located. Hope this helps you out.
Old Dec 27, 2001 | 03:31 PM
vteg's Avatar
New User
Good luck getting to it. It is a PITA.
Old Dec 27, 2001 | 04:16 PM
Volcom's Avatar
sorry i have a 94 rs with 122,000 miles on the clock. If i do want to replace it, where can i buy the part, honda? acura? autozone?
Thanks for the help
Old Dec 27, 2001 | 04:33 PM
jonsteR's Avatar
I would just buy it straight from honda/acura. Should cost that much.
Old Dec 27, 2001 | 08:51 PM
TrustGs-R's Avatar
New User
it's where BSQ said...basically, it's on the back of the block on the passenger side of the stock oil separator can. You can replace it with a fram from kragen or autozone (it's as good as the stock one with a slight better flow rate).
Or you can get the stock one. They're under $5.
Old Dec 27, 2001 | 11:42 PM
Volcom's Avatar
Default Re: where is the pcv valve? (TrustGs-R)
thanks for the help that is what i needed to know
Old Dec 28, 2001 | 08:30 AM
Sloth's Avatar
New User
SecondHonda
Aug 8, 2015 10:41 AM
SupaTegRS
Dec 23, 2002 08:33 AM
Teg44
Jun 19, 2001 11:17 AM
