How hard is replacing the o2 sensor in a 2000 'lude?
Old Nov 15, 2004 | 07:51 PM
3WL's Avatar
3WL
Default How hard is replacing the o2 sensor in a 2000 'lude?
Hey all, I was recommended this site from the auto-fanatic goons on the Something Awful forums when I came to them with my 2000 Prelude's problem.
Here's my car's problem. I took my 2000 prelude to get checked out because the check engine light was on. The code that came back was P0133, which according to the mechanic means the 02 sensor near the catalytic converter is out of commission. This problem sounded serious enough that I was ready to get the repair done on the spot, until I heard they wanted $500 for the job. I'm wondering if I can do this work on my own for less money, at low risk, and in a reasonable amount of time. A manual that I might need was mentioned. Are there any good spots to buy Honda o2 sensors that you know of?
Thanks in advance.
Also, my local dealer wants $500 for the 60k tune-up. Is that reasonable in your opinion?
Old Nov 15, 2004 | 08:21 PM
blackdelslo's Avatar
Default Re: How hard is replacing the o2 sensor in a 2000 'lude? (3WL)
$500 is wayyyyyy to much for an 02 install.
All you need a jack and some jackstands to lift the front of the car up. Get on your back and change it with a wrench.
Honda OEM o2 sensor will perform the best, dont go cheap on it.
#18 $185.82
http://www.hondaautomotivepart...+PIPE
Old Nov 15, 2004 | 08:28 PM
mathews's Avatar
5 bills? what kind of grease monkey is this?
Easy job! diffinetly get the honda part. Don't forget to put some antiseize on the threads so it wont cold-weld.
Old Nov 16, 2004 | 03:23 AM
littledan's Avatar
Default Re: (prylwd)
yes definitely diy... you will have a tough time getting the old one out but don't give up... you can buy the o2 sensor and a manual from http://www.helminc.com for less than what the dealer wanted damn.
Old Nov 16, 2004 | 07:38 AM
prelude1897's Avatar
Default Re: (littledan)
This is real easy to do. Just get under your car, disconnect the sensor, and undo it from your cataylic convertor, and put your new one in, then do everything in reverse. If you sensor comes out with ease, this should probably take you about 20-30min. to do
Old Nov 16, 2004 | 10:18 AM
LudeyKrus's Avatar
Default Re: (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">This is real easy to do. Just get under your car, disconnect the sensor, and undo it from your cataylic convertor, and put your new one in, then do everything in reverse. If you sensor comes out with ease, this should probably take you about 20-30min. to do</TD></TR></TABLE>
Yup. But it takes a bigass wrench to do it. Go get a big crescent wrench that goes over 24mm or so, so you don't have to worry about getting the right size.
Installin an O2 sensor should take no longer than 20 minutes.
Old Nov 16, 2004 | 05:31 PM
PrettyLude's Avatar
use a 7/8 wrench to break it loose
Old Nov 19, 2004 | 04:26 PM
3WL's Avatar
3WL
Default Re: How hard is replacing the o2 sensor in a 2000 'lude? (delLudeVTEC)
I went to this site:
and there seems to be 2 sensors. Which one do I remove and replace, I wonder?
Thanks in advance.
Old Nov 20, 2004 | 09:28 AM
silentvoice19's Avatar
ha ha i had the same problem in my 2000 SH i have no giant mechanical backgroud and it took a friend and i 25 mins and i bought the cheap one you have to cut the wires and put then back on the cheap one was 75 bucks and works like it was stock.
spoonzdelsol
Jan 25, 2013 08:04 PM
02crv
Honda CR-V & Element
Mar 13, 2011 06:02 PM
bmarchio
Jun 17, 2008 06:29 AM
