Cofused by Helms
Old Nov 15, 2004 | 07:49 PM
silentblackhat's Avatar
Default Cofused by Helms
I have a 99 EX 4dr civic. i am looking at my helms and i am trying to figure out what steps to take to change my clutch. i dont see where it says to take the transmission cover off to get to everything. does anyone know what page numbers in the helms i can look at for that?
Old Nov 15, 2004 | 08:26 PM
MassScene's Avatar
Default Re: Cofused by Helms (silentblackhat)
Dont put a clutch. Put a swap.
Old Nov 15, 2004 | 10:48 PM
l2agnar0k's Avatar
Default Re: Cofused by Helms (MassScene)
http://www.honda-acura.net/for...39802
might help you
Old Nov 16, 2004 | 06:35 AM
MassScene's Avatar
The money you spend on a clutch (especially if aftermarket) is a big chunk of the price of a swap (bseries). Then you could sell your singlecam and get some more money back.
Old Nov 16, 2004 | 07:01 AM
MasterKwan's Avatar
$300 for a clutch or $3000 for a good B Series? I'm with you on the swap, I just think the math is a bit off.
As for doing the clutch, How does the helms show you pulling the tranny out? That's the procedure to follow. It's got to come completely out to do the job. You (at home anyway) typically have to disconnect the passenger side suspension too so you can pull the axels out.
Old Nov 16, 2004 | 07:11 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 EX 4dr civic. i am looking at my helms and i am trying to figure out what steps to take to change my clutch. i dont see where it says to take the transmission cover off to get to everything. does anyone know what page numbers in the helms i can look at for that?</TD></TR></TABLE>
You don't see where it says that because it doesn't. You don't take a "transmission cover" off to change a clutch, you have to remove the transmission from the engine. Follow those steps in your manual and you'll be fine.
Old Nov 16, 2004 | 08:31 AM
civicminded92's Avatar
MassScene:
The guy is trying to change his clutch. Not swap. Did he mention anything about swapping? No? It's akin to going to a restaurant and asking for a hamburger, and they suggest having a chicken pot pie. Did you want the burger, or the pot pie?
silentblackhat:
The link posted by l2agnar0k looks very nice.
Old Nov 16, 2004 | 09:08 AM
BauleyCivic's Avatar
Risky Business
Default Re: Cofused by Helms (civicminded92)
Look under the transmission removal section. Once you take the transmission off the clutch is exposed.
Old Nov 16, 2004 | 03:02 PM
MassScene's Avatar
Default Re: Cofused by Helms (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">$300 for a clutch or $3000 for a good B Series? I'm with you on the swap, I just think the math is a bit off.
Are you trying to tell me he couldnt get a legit b18b for 14-1800. come on now. But your right he ididn ask my opinion.........but i like to give it.
Old Nov 16, 2004 | 03:10 PM
TeamNextGenChris's Avatar
first thing you need to consider is if you have the knowledge to do this by yourself.judging by your apparent lack of familiarity with how changing the clutch works,i'd consider giving this job to somebody a little more qualified.that being said,it'd be a great learning experience-just be prepared to go without a car for a while if you get hung up somewhere.you did the first thign right by buying a Helm manual.
look in the Helm for the procedure on removing the tranny.then look at the section on replacing the clutch.i don't have my Helm here,so i can't give you specific page numbers,but looking at the tranny section's directory page should tell you where to go.
chris
NeedyGTI
Sep 12, 2005 02:19 PM
wafflehead
May 11, 2005 07:55 AM
dturbo
Oct 3, 2003 01:26 PM
TurBoXBirD16
11
May 17, 2002 06:55 PM
