Oil Sending Unit Problems, The Unit Broke Of Partially Threaded In The Block How Can I Fix This
Old Nov 15, 2004 | 07:27 PM
ImThatGuy's Avatar
Default Oil Sending Unit Problems, The Unit Broke Of Partially Threaded In The Block How Can I Fix This
As I stated in the title the sending unit broke partial threaded in the block, how could it have broken, the shop I had it installed in used silicone to thread it in an a brass oils ending unit I call
Old Nov 15, 2004 | 08:55 PM
nub.96ek's Avatar
Default Re: Oil Sending Unit Problems, The Unit Broke Of Partially Threaded In The Block How Can I Fix This
Get an easy-out from sears for $8. It's reverse threaded... as you tighten it into the broken portion it will grip and pull it right out.
DOWNwithHT
Aug 17, 2007 05:36 PM
TypeSLO
Sep 11, 2006 12:40 PM
mo0cow
Oct 26, 2005 04:36 AM
