D15B Engine swap wont start...HELP
Old Nov 15, 2004 | 06:53 PM
Double_Dk's Avatar
Default D15B Engine swap wont start...HELP
Hey all.
Just dropped a D15B in my winter beater and the snow is coming so I got to get it running ASAP.
The engine is in, and all the JDM wiring has been done and triple checked. It's all good.
Here's the problem
Turn the key, and all you hear is a click.... That's it. The engine doesn't even try to turn over. I tured on the head lights and tried starting it to see if it was a bad ground, but the lights stay on full.
Anyone know what it is?
Old Nov 15, 2004 | 07:00 PM
dr_latino999's Avatar
Default Re: D15B Engine swap wont start...HELP (Double_Dk)
Bad starter possibly?
Old Nov 15, 2004 | 08:20 PM
neveruns's Avatar
sounds like Starter or battery
Old Nov 15, 2004 | 08:42 PM
Luserkid's Avatar
Default Re: D15B Engine swap wont start...HELP (neveruns)
I would go with a bad Batt. since you said it clicks.
Try jump starting it.
Old Nov 16, 2004 | 02:19 AM
Double_Dk's Avatar
we used the batt in another car just mins before I put it in mine.
Also, not sure if I said it, but I got the car to bump start.
I'm pretty sure it's not the started. With the key in the ON possition, you do not hear the fuel pump turn on.
Anyone????
Old Nov 16, 2004 | 04:16 AM
BigPlansNoMoney's Avatar
Also, could that be caused by a bad alternator?
Old Nov 16, 2004 | 07:14 AM
DaX's Avatar
DaX
Loved
Community Favorite
Check all your grounds. I had this problem and it was my transmission ground. Make sure they are tight, and you might want to remove all of them, lightly sand the contact surfaces, then tighten them back down.
Old Nov 17, 2004 | 01:22 PM
Double_Dk's Avatar
If I short the ING to the starter under the hood with the key in the on poss, it fires up.
But not by turning the key.
Anyone
Old Feb 2, 2005 | 05:06 PM
rexizbest's Avatar
Default Re: (Double_Dk)
check your main relay. if the car has been sitting cold for a while the solder on it may have cracked. happend to me once....pocket one from a junkyard & see if it works. very easy to do, so might as well try it.
Old Feb 2, 2005 | 05:10 PM
Double_Dk's Avatar
turns out the clutch sensor wasn't working, so the ECU didn't know the clutch was pushed in when trying to start it,
Old Feb 2, 2005 | 05:11 PM
rexizbest's Avatar
Default Re: (rexizbest)
woops...didnt realize how old the post was. hopefully its running by now
SpeedSeeker21
Sep 29, 2013 12:17 PM
dtran002
Dec 5, 2012 09:29 AM
acura_el2000
13
Sep 11, 2011 09:54 PM
importdreamer
21
May 8, 2008 02:08 PM
silver hatch
14
Mar 29, 2005 05:08 PM
