Installing 2K1 USDM Type-R header->exhaust on 95 GS-R
Old Dec 26, 2001 | 10:22 PM
PhilJ95GSR's Avatar
New User
Default Installing 2K1 USDM Type-R header->exhaust on 95 GS-R
I'm finally going to put this USDM header, cat, b-pipe and exhaust on my 95 gS-r and am wondering what I need to buy before I try the install. I have guys to help me and the equipment but what gaskets should I buy, what size/kind of bolts will I need and especially what should I buy to plug up the extra O2 sensor hole? Thanks..
Old Dec 27, 2001 | 11:06 AM
PM-Performance's Avatar
Default Re: Installing 2K1 USDM Type-R header->exhaust on 95 GS-R (PhilJ95GSR)
why exactly are you converting over. ?/?
just because its type r doesnt mean youll gain power from it . esp the manifold and the exhaust. . . its very similar to your stock set up .
but whatever's clever.
your closer to owning a type r now .
Old Dec 27, 2001 | 11:31 AM
IN VTEC's Avatar
Forget it and save your money for a real header.
Old Dec 27, 2001 | 11:32 AM
ingrate's Avatar
25 Year Member
Default Re: Installing 2K1 USDM Type-R header->exhaust on 95 GS-R (itr206)
i think you can just reuse the old nuts and bolts from your old stock header/exhaust. just use regular hand tools. you'll want a nice floor jack and some jackstands. the ITR header/exhaust flows better than a GSR's and also costs less than most aftermarket pieces.
Old Dec 27, 2001 | 02:16 PM
Default Re: Installing 2K1 USDM Type-R header->exhaust on 95 GS-R (In7egrity)
i think thats a crock , the exhaust maybe possibly flows a little more. but the header i dont beleive, i still have the manifold from my 99 teg gs and my type r and looking at them dont see nay diff . . . . now the jdm one is a whole diff story. that will be the best money you can spend on that thing.
but like i said whatever is clever.just expect to not feel any diff and not really see anything on a dyno . . .
Old Dec 27, 2001 | 07:01 PM
PhilJ95GSR's Avatar
New User
Well I needed to replace my stock exhaust so I went with the Type-R exhaust, I was only going to buy the exhuast but it wasn't much more for the b-pipe,header and cat and I got those so it would fit perfectly. I know I won't gain much power , I was expecting like 3 whp max from it. So what should I use to fill up the extra O2 sensor port? Thanks.
Old Dec 27, 2001 | 07:23 PM
speedymon's Avatar
So why did you spend money if you're not gaining anything. That's ghey!
Old Dec 28, 2001 | 02:13 AM
ingrate's Avatar
25 Year Member
it's his money.. don't gotta knock him for it
FYI, an ITR exhaust flows 30% better than a GSR's and by using the ITR header and cat, he doesn't have to modify the exhaust to make it fit. he'll probably have a better chance of selling it later this way. plus i'm willing to bet the new cat is in better condition than his old one..
and sorry, i don't know the answer to your extra o2 hole question. maybe you could find a small bolt with the same threads and just screw it in?
Old Dec 28, 2001 | 06:05 AM
if you go to an exhaust shop they have like plug things for the hole that just screw in like a bolt. . . i got one on my test pipe , cus they put the 02 bung in the wrong spot, so i plugged it up and now got it in the right spot. . . . universal
Old Dec 28, 2001 | 06:06 AM
Default Re: Installing 2K1 USDM Type-R header->exhaust on 95 GS-R (speedymon)
Old Dec 28, 2001 | 07:07 AM
maggsgsr's Avatar
The R exhaust is pretty cool,but the US R header?Makes no sense to me,the JDM makes sense thow.But whatever floats your boat.
Pinner13
Oct 5, 2010 12:36 PM
krazykay5487
Jan 7, 2007 09:53 AM
00PurpleGSR
Apr 8, 2002 12:43 PM
