Replacing OEM Cam Seal
Old Nov 15, 2004 | 04:35 PM
billyhoe's Avatar
Default Replacing OEM Cam Seal
when u replace the oem cam seal on the exhaust cam side, is it required for u to take off the timing belt and put engine in TDC?
Old Nov 15, 2004 | 06:05 PM
boosted k20's Avatar
Default Re: Replacing OEM Cam Seal (billyhoe)
if ur just putting on the cam seal (not the rubber O ring, but the solid round peice by the exhaust side closer to the distributor. like the ones that STR sells) then theres no need to take off the timing belt off. just take off the last cam cap. then u just need to remove the old cam seal and install the new one
Old Nov 15, 2004 | 06:27 PM
sabotage7's Avatar
is this what you're talking about? http://www.team-integra.net/se...D=576
if so, that article will help alot!
Old Nov 15, 2004 | 06:50 PM
Default Re: Replacing OEM Cam Seal (sabotage7)
oh yea, if u have a LS, then it should be pretty simple. just take the valve cover off and unbolt the last cam cap.
if u have a VTEC motor, u will need to take off the top plate from the exhaust side. then after u do that, just unbolt the last cam cap, take out he cam seal and install the new one
cadeMFjohnson
Apr 21, 2009 07:54 AM
jdmjeff
Dec 17, 2007 02:19 AM
94 IntegraLS
May 25, 2007 04:41 PM
vlc92189
Mar 15, 2007 05:34 AM
MattyP
Oct 14, 2004 03:59 PM
